I replaced my EGR valve and EGR modulator but I still get this code. Any ideas what might be causing it to recur. Thanks
Have you made sure that every vacuum passage involved is clear and that the VSV is operating properly and all vacuum hoses are intact?I replaced my EGR valve and EGR modulator but I still get this code. Any ideas what might be causing it to recur. Thanks
I have two questions.
1. Where is the VSV located. Can I replace it without removing a bunch of other stuff.
2. In the attached photo, what is the hose with the arrow on the left (P/N?). This one has a crack in it at the base. Might that be a cause of my problems. Is the one on the right coming from the PCV?
Thanks
Doug C
