EGR Diagnosis
Jamestown, NC
First of all, I am a fairly new LC owner. I picked up a 94 with lockers and a blown head gasket in the spring. I have since replaced head gasket (along with a lot of other things during tear down) and am now trying to work the bugs out since the car sat for nearly 2 years prior to me getting it.
I had a EGR code. The metal nipple on the EGR valve where the vacuum line connects from the passenger side was broken off, so I sourced a used EGR valve from a member here. Cleared code and now it is back. So I have an issue somewhere else, guessing the VSV as all vacuum lines are new. Does anyone have a way to diagnose a bad VSV to be sure it is bad? I hate throwing parts at a car if I am not 100% sure it is the culprit.
Thanks in advance
Unplug the EGR temp sensor and short the wires together. This will clear the code permanently.
More likely to be a bad modulator then a vsv. I would check the modulator first.
Find an FSM and start reading. There are several ways to test each part
And if you get new switching valves bench test them. I got a bad vsv from Toyota right out of the box
That doesn't actually fix anything.
The only FSM I am seeing is by subscription....is that the only way to get it? No one has diagnostic procedure handy?
