EFI Relay overheating woes
So I have one of those Cruisers that has had weird electrical issues and burned up 3 alternators in 4 years. This time around I noticed a pattern of the EFI relay acting up for a while (more on that later) before there's battery drain issues and eventually the alternator going zap. I've felt sure there was some small intermittent short in the engine wire harness that was contributing. After connecting the new alternator this time I had a full dead short when I went to reconnect the battery. Unconnected the alt and everything was ok. The short had to be right at the alternator! I pulled off layers of what appeared to be ancient gummy crappy household electrical tape. I cleaned the wires and connectors and rewrapped with tough self fusing high temp rubber tape and managed to get some plastic looming around it and made sure nothing close to the alt could pierce or cut the insulation and the connection was clean. I also replaced the EFI relay and fusible links. Everything has been excellent since then and I was feeling that maybe I finally licked the problem that has plagued my electricals since I bought the truck. Until today. Today the week-old EFI relay overheated and killed my engine on the highway in San Francisco on a crazy ass traffic day (Obama is in town). Luckily I was just exiting and was able to stop safely. I had a feeling what it was and deployed my trusty EFI relay bypass jumper wire, which immediately put me happily back on the road. The usual EFI relay problem is this: I drive somewhere then stop. If I try to start again too soon, the engine cranks but wont fire. I learned that the engine will fire as soon as EFI relay is cool enough. But today the EFI relay killed the engine in transit! When I pulled it out it was sizzling hot. Why does my EFI relay get so damn hot?
When my rig died on a trail, I checked the EFI relay first. Man, that puppy was HOT! I thought that was it (had no CEL). I swapped in my spare relay (from power window bypass) but no luck. Turned out to be a defective fusible link.
That relay was so hot I could barely hold it, but it was still working.
I would guess it is the coil causing it to get so hot. If it were the contacts, you'd have to have a big voltage drop and I'd expect other problems to show up due to that.
I've read where people have relocated the relay with a harness extension.
I've never had a problem with my efi relay, like above I thought it caused a stall at altitude once but I think what happened is the charcoal canister over pressurized the fuel system causing a stall. But they do get hot, but so does allot of other stuff under the hood. I did squirt some dialectric grease in mine though for good measure.
The relay was rewired about a year ago and the connections all seem good.
So does the relay overheating like this really not indicate any problem other than with the relay itself? No underlying problem to address that is causing the overheat? If this part (I got Toyota OEM) is that under-spec'd then this should be happening to everyone right?
I ascribe to the theory that corroded contacts in the relay circuit cause 'arcing' which superheats the relay, which is why I use dilectric grease in there.
The EFI relay on my '97 gets crazy hot. Like instantly burn your fingers hot. I don't know why. I know earlier models had thinner wire than should be upgraded.
I assume the control voltage for the EFI main relay is 12VDC. Anyone know the amp rating for the power contacts? I'm thinking about just using a better relay, mounted where I can and patched over to the connectors.
Thanks, I did run across that earlier today Darl, and also lots of instances of this happening and it being solved sometimes just by making sure the relevant wires are in decent shape, and sometimes that plus relocating the relay away from the hot environment it normally lives in, like into the cab under the dash. I need to stat with really checking out the wiring under the box under the hood. A moment I have dreaded, but I don't think either of the two folks I've paid to get in there are really more electrically skilled than I am, and I'm more motivated. At the moment I am using a jumper across the relay power pins, and unplugging it when I park so as not to drain the battery. In messing around today I happened to grasp that jumper connection right after starting the engine and observed it getting almost too hot to hold within about 15 seconds. Makes sense there is some degraded wiring causing a voltage drop and hence excessive heat. Anyone concur?
I'm not sure about this exact problem but I have worked on ambulances quite a bit(every one a custom wiring headache) and typically when something is getting hot there is an issue with the ground side somewhere. I had one of ours blowing up 100 amp fuses and smoking onboard chargers. I was pulling my hair out until in desperation I tried putting another ground wire on, and it completely solved the problem. Have not had a single issue with it since. That was a real eye opener.
My 80 now has dual 6 guage ground wires on it- one to the frame and one to the body, both with soldered terminal connections. This is in addition to the factory grounds to the engine and starter. No issues noted so far. Also replaced the fusible links recently just as a preventative measure. For $20 it's cheap insurance. Hope this helps.
Thanks Jon, I've read that many times. A slideshow depicting the actual replacement of wires/connectors is the kind of hand holding that would comfort this newb. Also, you mention putting a "bunch of new ground wires throughout the system." How and where do you install these? Thanks!
Do you own a multimeter? If not buy 20-30 dollar craftsman or if you want to invest in a good meter a base model FLUKE is a great tool to own. Then remove your jumper wire. Set your meter to AMPS put leads into COMMON and AMP on meter and set dial to A place them where your jumper was. Start the truck while monitoring the meter. If it spikes above 10AMP immediately shut truck off as it will pop the fuse inside your meter. (make sure your meter is good to 10A, most are)
The fact that you said your jumper was almost too hot to touch tells me your AMP draw may be well over spec and causing the repeated failure. To correct I would start by isolating the fuel pump and running it with direct battery power while checking AMP draw. If draw is still over spec, pump is bad.
All that being said I have no experience with EFI relay problems on the 80 series but lots of experience diagnosing electrical issues.
Maybe someone more experienced on the issue can confirm or deny that the EFI relay is in fact powering the pump before you do this test though as I was just assuming but am now second guessing its purpose in life
My EWD says the fuel pump is NOT powered by the EFI relay.
It is powered by the fuel pump relay which is actuated by the circuit opening relay.
Wrong engine. The EFI relay provides power to the fuel pump. The circuit opening relay is the fuel pump relay in a 3FE.
Just so we're clear here as I'm looking at the 1996 EWD, the fuel pump +12 originates from the EFI fuse, through the EFI relay, through the circuit opening relay, through the fuel pump relay, and finally to the fuel pump.
So on both motors the fuel pump is supplied with +12 from the EFI relay. There is more logic involved with the later 1FZ-FE but the power source is identical.
