EFI fuse
If your 96 is the same as my 93 it is in the fuse box under your hood, on top of the driver-side fender, there is a fuse layout diagram on the box, my EFI fuse is a 15amp in the lower right quadrant of panel....................if you are pulling the fuse to reset your CEL expect some odd engine/start/idle/rpm behavior for a couple of starts until it re-educates itself.
edit: I think your 96 has the newer OBDII system you may have to reset with code-reader.
