eek problems
Santa Monica, CA
Website
www.elirubelphotography.com
OK so big (stupid) problem today in the garage.....
SO I have a push button start...and it will work about half the time??:confused:
Here is how I have it wired-
Button gets power. button has wire come out of it that goes to a hidden switch, which then puts the final wire to the starter soleniod.
HERE is the wierd part: When I disconnect the wire described above from the solenoid...and test it, every time I press the start button it WORKS.....so that cant be the issue....
AND - when I test the starter solenoid terminal while it isnt connect to anything, it reads as being grounded.....
SO both of those are as they should be and functioning A OK
BUT- when I put the two together, they act like an open circut like the power to the soleniod wire is effed somewhere???? but if it tests fine by itself every time then something about putting the two togetther messes everything up.....
AND to make things worse, it works SOMETIMES which REALLY confuses me?????? :confused:
HELP ME
:crybaby::crybaby::crybaby::crybaby:
Im sure its just some obvious thing and im too HIGH on gas fumes and such to realize...
So flood me with ideas please.
THanks
:cheers:
maybe pull all electrical connections apart, including ground from/to frame and or engine from battery -post and clean all up. seems silly but even small arcing (Sometimes works sometimes doesn't) will cause full interuptions with current draw.
try a new switch/button combo of the sorts. These guys are rated for certain voltages and amperage and will burn out pretty quickly if not spec'd properly. Also make certain you're using fairly descent gauge wire and CHECK THE GROUNDS!!!
Maybe you are confusing voltage with power? The wire may have a voltage on it when you press the button, but it doesn't have enough current to operate the solenoid. Maybe a bad connection somewhere.
Could also be a bad solenoid. Have you tried jumping the solenoid start terminal directly to the battery cable?
Yea when I bridge the connection it works fine...so the starter solenoid is good....I will take a volt meter tmrow and find out if im getting a full 12v when I press the button...
If my switch always works as long is its attached then how could it be bad...? wouldnt it either work or not?
Ill check my grounds again tmrow.
It wouldn't have to be dirt that contaminated the connections. If you happened to have a loose connection and or bad ground resulting in some arcing causing a block in the pathway. Sometimes when you have a poor connection and the current draw/resistance creates enough heat it could temporarily complete the circuit
I will take a volt meter tomorrow and find out if im getting a full 12v when I press the button...
You need to check the voltage while the wire is hooked to the solenoid to get an idea of whether it is providing enough power (volts x amps). If the voltage at the solenoid is less than 9-10 V, the wire isn't passing enough amps to operate the solenoid.
