Build Ed’s Un-Did FJ40
The bodywork bonanza continues…..
Just a WEE crushed
Cut the spot welds, several had graciously let go during the rollover saving me the effort 🤣
All that’s left of the poor original inner sill. Need it for a template now
Onto the rockers. Both the outer and inner.
Cut the braces out because they need to become templates. The sandwiched metal Toyota rust phenomenon is… 🤢
And this tub has been stored inside, dry, over 25 years
Driver side is zipped off here
Passenger side. WAY worse. Ed believes he mistakenly left a can of muriatic acid next to it which actually ate this hole right through the rocker
These cuts are “rough” with a sawzall. I’ve got a very precision line scribed on it which I’ll clean up to later
And oddly, found this wood jammed inside the driver side rocker. Only way it could get in was when the hardtop was off, down through the round hole in the “B” post
Pulled the tub outside and spot blasted all the seams we opened up. That layered rust is ridiculously hard
Rocker before
After blasting the seam
“B” post area
Driver side fender seam. This is at least clean enough to start welding on and reassembly
Gross. Thankfully I’m up to date on tetanus
Removing this inner fender was quite literally the definition of “not fun”
Not sure what year this donor piece is/was but it had much larger supports in the under fender well area and Toyota had clearly upgraded their spot weld machine. SO much harder to get it separated than the ‘69 tub
Got some new rocker bits bent up by a friend of ours, 16g cold roll. Welded it in, EXTREMELY slow
Outer is on
Massaged the replacement driver rear inner fender into place
The reinforcement rib will get capped and extended out to the rocker eventually
Passenger side rocker repair is in…
