ECU Units
I was thinking about checking the coil and all the wires to it because at idle it will be fine for 30 seconds at 625 or so then it will drop and lope between 400 and 600. I was thinking the coil is going bad and at low rpms and low amps it struggles to keep a good spark.
Is the easiest way just while it is running check to see if there is the proper output from the coil?
It has all new spark plugs, and wires, cap, and rotor.
Check the air intake hose for cracks.
Engine stumble
My truck has a stumble/misfire issue. I will not go into all of the things I have done trying to figure it out. I will post all of it later. But I have a few suggestions on things to try. If you think it is the coil, go to Harbour frieight and buy an Ohm meter. Not the $2.99 one. I bought one for $10 and it worked great. I have never used an Ohm meter before, but it is not hard to figure out. I found the test numbers in Chiltons repair book- you need to know the resistance. All of my reading were within acceptable limits. I also tested everything I could find that could be tested. They all tested fine. My next door neighbor suggested that I look at the engine in the dark for a blue glow on the ignition wires. I told him I did that last week and saw no blue light. At wits end, I waited until dark to try again. Lo and behold the coil wire to the distributor was glowing blue. Every time it glowed, the truck would miss. These are brand new wires. The Distributor and rotor are only a year old. I am going to replace both Friday. THe moral to the story is- don't overlook new parts they may be bad. Look for the blue glow.
Good Luck!
Ill try looking at it and seeing working on getting a tester to try and test all of the ignition compenents.
Dan I have checked the hose and there are no leaks even put water in it and sealed off the ends to see if there was some kind of leak and nothing.
Everything that I have replaced is OEM toyota parts. I have gone the cheap route before with my other cruisers and you get what you pay for.
What has me stumped and thinking it was the ECM was that sometimes it will run great and have lots of power then another second it will run all right but just have no power. For example going up a certain hill when it is running properly it doesnt have to down shift and will cruise right up but other times it will have to down shift and work hard to get up the same hill. I was thinking this was the computer not sending the right information all the time.
Figured if the coil was going bad it wouldnt go in and out like that it would just be consistently poor. Getting ready to take it in somewhere and have them figure it out.
I'm in need of the '93 ECU/ECM after running through a handful of things and having the dealer look at it. Let me know if it is still available and price.
PM sent
