ECU Relearning
Columbia, MO
Question for the 93-94 guys. When disconnecting your battery or pulling the EFI fuse, do you even notice, to a great extent, that anything is relearning as far as low idle/high idle, etc? I've disconnected my battery or pulled the EFI fuse countless times in the past two months during the process of figuring out a cold start problem and notice no "relearning" occurring like so many people speak of. Mine starts up and idles just like it always does. I'm curious if this behavior may have something to do with my loss of high idle at cold starts. Thanks.
Dont know how much help I will be since I have a 95. But everytime I disconnect the battery my ECU has to relearn. I go out for a drive and stop and turn the truck off and back on about 8 times. After that it will idle perfect. But before that it will idle at about 250-300 RPM, just enough not to die.
Interesting. Yah, I don't get anything like that. Starts up and runs smooth 600+ RPMs in park.
Do have a 94, notice definite change in cold start idle up and idle stability for a while after fuse pull/battery disconnect.
Fresh 02 sensors? I suspect these play a large part in how the ECU goes through its learning process.
O2 sensors are about 5 years old. Replaced with OEM.
Bump for a new week. I'm still trying to figure out why pulling me EFI fuse or pulling my negative battery cable does not effect my idle at all. Starts up just like normal and runs smooth. No relearning "mode' going on. It will clear any CEL codes I had so that part is working. I believe this is related to why I have no more high idle upon cold starts each morning as well. It's as if I'm constantly running in closed loop. Just a theory.
Yeah. My 93 idles low for a number of starts before it relearns proper idle. Did you end up replacing the ecu with the updated 94 ecu?
My '93 has a definite idle relearn period. Have you removed or modded your cold start circuit? Not sure if that will impact it?
Yep, no change. I've had three different IAC valves on it and two different TPS on it. I've even got a different throttle body on it now with different IAC valves and TPS--absolutely no change. So at this point, I do believe it is electrical in nature, ie, something not telling the ECU to go into Open Loop on a cold start OR it's going into open loop but not being told to idle higher. I've replaced so many things with OEM parts: plugs, coolant temp sensor, fuel filter, fusible links, intake hose, PCV and hose, blocked off the EGR valve, etc.
Not sure what you mean by a cold start circuit or how I would remove or mod it? Glad to hear you've got a '93 that relearns. Definitely tells me mine is acting incorrectly. 8 degrees out this morning. Fires right up, revs to 1200 and instantly drops to 600-650 as it would if it were a totally warmed-up engine. Doesn't run rough. Runs just fine. Just no high idle.
Looking for any more theories on this from the day crowd since I bumped it a little late last night. ;)
For what it's worth my '94 doesn't show any difference either. I have pulled my battery a few times recently and there was no obvious difference in idle or any other part of the drive cycle.
Interesting. Thanks for chiming in. What is your cold start idle speed?
With the aircon off my cold idle is 1400rpm. Stays there for maybe a minute then drops to around 900. When warmed up she idles around 650. These are from memory so I will confirm tomorrow.
Isn't that just about perfect?
I have removed the battery for this or that a bunch of times and had no relearning, that I noticed. Started, idled, and drove normal. 95 lc with obdI
You're saying that you don't get a high cold start idle?
Do not disconnect power from the ECU (aka disconnect the battery) before an upcoming smog test.
Disconnecting the battery, even momentarily, will reset the OBD-II monitors and they will no longer show a ready status.
Any vehicle that does not display OBD-II ready status at a smog inspection (actually prior) will fail automatically.
Peoples Republic of California - Smog 2013
I mean the truck did everything correctly, as it had been, after having removed the battery. This was true a number of times, provided I didn't adjust or change anything important.
However, when I removed/cleaned or replaced t/b vsv vcv tvv pcv egr tps iac hoses etc. there was obvious re-learning. Was fully expecting this relearn, as I found defective parts and clogged hoses etc..
ps. read through your no cold high idle. did so as I had very high and searching idle.
pss. does your truck have temperature vacuum valve?
I would assume so. What are you thinking?
