ECU part # compatibility
"the whale's vagina", CA
anyone know if a 97 lx450 computer will work in a 96? I am trying to pick up a trail spare and found one from a lexus but the #'s are different. My truck is a 96 fzj80 toyota. Looks like both part #'s are different in my 96 vs. the 97 but toyota shows the same computer for all landcruisers 95-97?
Noah
Should be fine. All that you would have to worry about is whether it's a California, federal or Canadian Or from a supercharged model. Those are the real limiters. Numbers don't so much matter. The numbers on my 93 didn't come close to matching the one I put in it from a 94 and she works fine. Both were federal emmision standard ECU's
Just curious why a supercharged model would be any different?
Kit didn't come with ecu, lots of kits added to otherwise stock units, doubting dealer installs swapped ecu. Just curious if there's a new nugget of info to learn here.
I've got the computer from my 96 if you want it to match. i removed it a few years ago when i did the Diesel swap. everything was functional when removed without issues
Making a generality based on previous dealings with ECU replacement in a variety of vehicles. The couple I replaced in supercharged models were not in toyotas, but generally the tune is different and sometimes an extra injector is required for fueling which often times results in needing a way to operate it. I just figured that toyota can't be too far off from other manufacturers. I'm sure that if the land cruiser supercharger setup doesn't require another injector that the ECM is probably just flashed and reprogrammed to handle the fueling needs of the supercharger.
Pic of my computer
no, the sc is a bolt on trd option, the ecu is no different
