Easy Gliding Windows, Ideas?
Traverse City, Michigan
Hello Cruisers,
I have a 1997 FZJ80 and it seems the windows are getting "sticky." By sticky, I mean that they seem to all have a less then easy time cranking up. They all seem to have different spots that they struggle a little more than normal.
My question is: Do you know of any "trick" to lubercating the velvet vertical glides so that the glass slides with better efficency?
I was thinking WD-40 or Sailing Track Dry Lubercant?
Mind, they do all work up and down...but would like to help them out a little...
Thank you for your comments!:)
Jason
1997 Black/Gray, FZJ80 Factory Lockers
There is a write-up in teFAQ on this I think. Look in the maintenance section. It's a common problem.
don't use WD-40, at best it will just evaporate at worst it will swell and distort the rubber, silicone spray works great.
11-05-06 09:55 PM
Romer There is a write-up in teFAQ on this I think. Look in the maintenance section. It's a common problem.
Ken,
What a kind and gentle manner in which you told him to "Search."
:grinpimp:
:cheers:
Short answer:
1) Permanent fix is to replace the rubber glides with new OEM.
2) Temporary fix is to lubricate periodically (weekly, monthly, as needed, whatever) with your lubricant of choice; silicone based, whatever. FWIW, I do use WD-40, and have for years. Two or three times per winter does the trick for my climate (Oregon).
Curtis
FZJ-80 Window Glider easy to replace?
Thank you guys for the replies.
This winter has been so cold that my windows will hardly move. I was wondering if anyone has any key points on glider replacement. I was also thinking that if the door panels have to be removed that I might as well do the replacement door speaker mod.
Thanks all either way!
Jason - HuletCruiser
www.traversecityvacationer.com
