SOLD Eastern Sierra, CA: 1982 4x4 Toyota Chinook
Status
Not open for further replies.
This rig has been my daily driver and primary dwelling for the last 5 years/80k miles. Every part of the drivetrain has been rebuilt in the last 75k miles, aside from the transfer case, which works great. The truck runs, drives, turns and stops excellently, and has a ton of upgrades aimed at practicality on and off road and reliability. The camper portion is rustic and could do with a makeover if you desire, yet is very functional as is. It has a solar system, fridge, diesel heater, lights, speakers, USB chargers, etc. I put this setup together from a 1982 4wd Toyota Pickup and a 1976 Toyota Chinook, and it has been thoroughly tested and refined over the years and miles. Gets 20mpg highway, 16 city/high altitude and cruises 75 no problem.
Some more of the build photos and adventures I've had with the truck are on Instagram @4x4chinook
The Truck Details…
Clean CA title, registered and insured
Original blue and yellow plates
Fully rebuilt engine at 262K
New tires
Brand new timing chain set
Brand new front brakes
RV cam
Aftermarket long tube headers
New distributor, Crane Cams (FAST) ignition box
Carb rebuilt at 310K
All aluminum radiator at 250K
Marlin Crawler rebuilt transmission at 250K (5 Speed)
Solid front axle rebuilt at 250K (all new seals, bearings, etc)
Rear axle rebuilt at 300K, IFS rear axle swap (wider, bigger brakes)
New rear U joints at 320k
Axles geared to 4.30
1” Master cylinder
63” Chevy springs
HD springs up front
GM single wire alternator
Battery Dr. Isolator (engine charges house battery, solar charges car battery too)
New Napa battery 8/2019
Bucket seats
LED headlights and offroad lights
Aftermarket head unit w/ radio, AUX, USB, SD Card
6x9 speakers mounted behind seats
Volt meter, USB charger in dash
Wood burl shift knob
Body in great shape, no major dents
Custom steel bumpers front and rear with 2” hitch receivers in both (front bumper damaged a bit)
The Camper Details…
Pop top off a 1976 Toyota Chinook
Deep cycle interstate battery (new 11/2017)
USB charging port, volt meter, 200W inverter
Costways 12V fridge
200W solar panel on roof
Diesel heater and 2.5 gallon tank.
Rear fold down table
Pneumatic actuated pop top (plumbed to tire valve for either bike pump or compressor actuation)
6’ 1” Head room
Slide out bed (twin size)/bench with memory foam mattress
Sink installed but no tank hooked up currently.
Truck is located in June Lake, CA, 3 hours south of Reno, NV.
Asking $14k, and open to offers
hey men, interested on the truck. can you send some photos of the engine and the inside of the camper? thanks
Status
