Wanted Early 40 Fuel Line
Status
Not open for further replies.
Gig Harbor, WA
Looking for the carb to fuel pump metal line including the clips that hold it to the front fo the head and the smaller clips that hold the vacuum line to the fuel line.
Also looking for the line from the pump to the glass bowl filter.
For a 61 FJ40.
Thanks
Bill
I probably have them, will look later.
If it's the same as mid FJ40's I have one........
It's not Dave. 1bbl comes in from the front; 2bbl 70-74 comes in from the side.
70eb... I do have the line fromt he fuel pump to carb, do you need the vacumn line also or just the clippy things?? not sure how many clips there should be,
do you need the glass bowl also? or just the line from the glass bowl to fuel pump?
Paul
Paul,
I'll take the fuel and vacuum lines. I believe there are 3 clips or so on them. Two that hold the fuel and vacuum lines together and one that holds them to the front of the head.
I would also like the line from the glass bowl filter to the pump.
Do you have the line going into the glass bowl filter?
Thanks
Bill
Paul,
Thanks
Bill
I'll have to look and see how many clips that are there. the fuel line into the glass bowl is just rubber fuel line, generic.
not sure what this stuff is worth?????? let me pull it off and see how I can get it shipped to you. packaged wise.
Paul
something like this?
Status
