Early (1966) Fuel Neck Question
Is the hole supposed to be there?
  • No
    Votes: 0 0.0%
  • Hmmmm I don't know
    Votes: 0 0.0%
  • Total voters
    6
Dynosoar
Slightly Disturbed
SoCal
Hi All,
Is the 40 fuel neck supposed to have a hole on the underside? Vent? See picks and post comments please. I don't want to weld it shut if I need it there it looks like it is a drilled hole not a rust perforation. The metal is solid. The hole is downward facing, and would vent/spill fuel outside of the cab.
69+ FJ40 chain attachment point?
Couldn’t find pics of older necks w/ chains attached to the vent hole. Did find some quotes from LITP regarding that
I've been busy the last three days. But I still have question about the gas caps. I checked the fill necks and the three smaller ones have the second hole in the tab on the bottom of the opening. The 64 cap is attached to the vent hole and my 68 I think was attached to the vent hole. The 68's gas cap was stolen in 1975 so it may have been attached to the tab in the opening. After thirty years I won't swear to how it was attached. But now I'm curious as to how they vented the 45s. I would have thought the 45 pickups would have been the same as the 40s. In the sixties the tank was the same, the filler neck was the only thing different with the tank. IDave in the picture of the gas cap with the hole, is that a small vent tube on the lip of the cap by your little finger? The newer gas cap looks to be double wall. Was that older gas cap double walled too? If it is it would make it easier to vent the cap. It just seems strange that they would use a different gas cap than the 40s. The LVs I could understand since they were made in a different plant. I drive my 45 every once in a while and had problems with no gas to the carb and thought it was crap in the tank. Now I thinking it might be because it isn't vented. It had a aftermarket gas cap when I bought it and I put one off of an 40 on it.:confused:
John
I'll check that cap that I pictured earlier. That is an old original gas cap with the original chain. It doesn't have the tab to attached the chain but two holes where your's has one hole for the vent. I don't remember any area that looks like your's around the opening. I have four of the filler necks from the FJ40s 63-69 and they all have the small vent hole. I hoping to get up to our cabin this weekend so I can check my 65 FJ45LPB (my oldest daughter is expecting and if she has her baby before this weekend I may have to wait another week). If it doesn't have the vent in the filler neck I might have to drill one unless the OEM locking gas cap I bought from SOR about ten years ago has one. It is still in the box (also stored at the cabin). Plus check the original one I have on there now that I think is off of a FJ40. It had something aftermarket when I bought it. I just think it's odd that Toyota vented the FJ45 pickups different than the FJ40s. While I'm at it I might as well check the tanks on the FJ25 soft tops. Their filler neck is part of the tank. That large FJ40 filler neck I pictured should be the same as the FJ25 hard tops.
Another way to check would be to find somebody who has parts books or micro fishe for both the FJ40s and FJ45 and compare part number for the gas caps. I wonder if they did them different to keep the pickups the same as the LVs that were being made somewhere else. That doesn't make any sense, so that's probably what they did. That way only one gas cap in the 45 parts book.
John
