I think it's the same spot that Marcin flopped oh so many years ago? The ledge on the way down if you've taken the creek crossing off the main road.
Lance - welcome to esteemed flop club! ... you have not the 'full wheeling experience' until you have flopped at least once... ha-ha. That flop below (in 2006 on the Island) I started the engine and drove out on lockers.
What is it with the instinct to stick your hand out the window as if you could stop it? I did the same thing.
Post op suggestion...
I wheel with the front sway bar disconnected. I find it allows the axle to move more freely and doesn't take the body with it when dropping down an obstacle. Good example is V-Rock. When I descend the body stays almost dead level when the front wheels drop down the dips near the bottom. With the sway bar on it feels way tippier.
Jeff I have simply put a S/S 'Speed Pin' in place of the bolts on the axle. Zap strap bar up to frame and voila!What have you done to make the disconnection easier? I vaguely recall doing it, or attempting to, and then said screw it because it was a pain in the ass with the OEM setup.
Ouch.
I think you now deserve that "gold Rolex" that Graham gave me after I did that to mine. Don't get excited, it doesn't work ...not surprising though.
Sounds like a day. That's to bad about your truck Lance but at least your OK.
How much damage to the side of your truck?
