IIRC the weakness of the 14 bolt is its lack of gear range vs the 60.
They sure are cheap, though.
Would it be easier to just bob the frame and throw an 80 body on a pickup?
just called randy's ring and pinion,(yukon axles) noboby sells 3.70 for the high pinion 8" front for an 80. sux
Thanks for checking! Is too bad there is no taller option for those final drive ratios...
ZF 6-speed has a 0.50 overdrive, which helps the issue. It's quite a gearbox. We're still thinking we'll go to at least 33s.
We have some ideas on how to get the TLC transfercase to bolt to it, but we are not sure if the front driveshaft will clear the transmisson and likely transmission shifter will be interfering with the dash.I think there's a reason Proffitt's requires at least a 4" lift and 35s their deisel conversions (They use the 4bt though, IIRC).![]()
What is a diehard gearjammer to do?![]()
