Dumpy Rear End - 1990 Toyota 4Runner - Rear end lift?
Hello, I have seen a common problem among 2nd gen 4runners that have less tire/fender clearance in the rear then the front. Looks really bad. What is the easiest/cheapest way to raise the rear end about 2". Thanks
you got sagging coils. I've never experienced it personally, but it's been known to be a common problem.
You got some choices, some are better than others but aren't necessarily cheaper.
1: a spacer. you still have the same characteristics as the spring you now, only the rear sits higher. Bottom out, weak, etc, etc
(personally, I wouldn't do it)
2: stock replacements. If I wanted stock height and a better, less prone to bottoming out coil, this is what I'd do.
3: ever want it lifted? now's the time. In my mind I'd deduct the price of a new or used coil from the cost of a lift coil replacement...then research lifting the front. CAUTION: it will handle extremely different and your CG will of course be higher (more prone to roll) but if you're a driver you'll know when (at least I hope) to get out of it before it does. And you'll be able to get those bigger meats under it. :cheers:
bigger meats need lower gears. and thus, the cycle starts...
Search the web for someone that sells Old Man Emu coils, should be about $120-150 per pair. It's a very easy swap, and you'll get about 1.5" of lift in the rear too. If you don't wheel the truck, you won't need new shocks, brake lines, anti-swaybar links, etc. I've done many of them, HUGE improvement. Way better than the Downey coils too.
or....stock FJ80 rears (IIRC) :D
I think I've got the end wrong, but find somebody lifting their 80 and smooch a pair..
I have had the Downey coils on mine for about 4 years without any issues. They have not sagged since the day I put them on. Even under a lot of weight in the back and towing a trailer they do not sag. Don't know anything about the OME coils.
