DUMB ***TS NEVER DIE!
new mexico
Was swapping batteries between my WAY too many vehicles late one evening, and failed to install battery in correct position in my 1996 LX450, just seeing that posts in "correct" position, but...obviously not, a brief fireworks display emitting! Anyway...
Replaced a burned through "fuseLink"; rotor and cap; ecu; and plugs. Symptoms of rough idling and shaking upon acceleration present. HAD to take vehicle on 120 mile RT yesterday, and really no issues other than those 2! Friend says he believes the #2 cylinder "dead"!
Help, Gentlemen! Vehicle has been bullet proof and...if kept away from folks who are sometimes brain dead - still will be! 133K and still strong! Probably one of the few Lexi to ever get off road, this one living on mountain roads, here in the Gilas, in SW NM.
In advance, thanks!
Oh sure, NOW you wanna join the forum when your ass is in the sling :flipoff2: <-- Mud board welcome salute!
Sounds like purely electrical. Did you replace the ECU because the other one went bad? They don't usually die, even with reverse polarity due to the myriad of safeguards in these things. I do have to wonder if you had enough drive cycles for the ECU to learn everything once again.
Need more information; do you have a check engine (MIL) light, pulled any codes (misfire)?
