Dumb Bikini Top Question
Alexandria, VA
Sorry for this. I did search.
Will a Specter bikini top work with the Bestop windshield channel? If not, would if be difficult to make it work?
Thanks,
Felix
I own a newer specter bikini (the killer Summer Shade one that is mesh) and it says you "must" buy their newer "Tiger Channel" as the newer channels are square while the older style bikini channels (likely what you have) are round IIRC - at least mine was like this. Well, I found I could use a brand new SOR top without the Tiger channel just fine as the square end of the bikini top stayed just fine in the older round channel. $27 savings...
I even wrote about it here: https://forum.ih8mud.com/showthread.php?t=81725&highlight=SOR+summer
hope this helps
I even wrote about it here: https://forum.ih8mud.com/showthread.php?t=81725&highlight=SOR%2Bsummer
hope this helps
AWESOME! I have one of those family tops I bought and then figured it wouldn't work with my Kayline/STC channel. Sounds like from your experience I can use my family bikini top with the Kayline channel after all. :D I'll have to give it a try...Although the top hasn't aged the minimum 3 years on the shelf yet :doh:
Sorry, I should have given more info. I already have the Bestop channel; it's the bikini top that I need.
I want to stick with the Bestop channel since that's what I use with the full soft top. If I but an SOR bikini top, will it work with the channels I have? It sounds like there's a new and old mounting style for the SOR tops? And either might work?
yes, I understood.
I am not sure of the Bestop channel style (round or square)? My point was more that if you have an older style channel - the round style - which you just might with the Bestop - all the newer bikini styles from Specter claim to require the newer square Tiger channel, but infact, my new SOR bikini works just fine with old round channel.... so if you buy one of their newer bikinis 'requiring' square channel and you have an older style round channel my experience shows that you should be good to go despite what they claim.... and I have used it everyday now for months on and off road, highway, etc.
what is the cross section of your Bestop front channel??
Heck...I thought all Bestop bikini tops (which I think an SOR bikini is just a rebadged Bestop) attached to the windshield channel via a thin long rectangular shaped piece that slid into a thin "u" shaped channel. And, I thought Kayline/STC used the rounded or cylindrical shape. It sounds like the "new" channel isn't really all that new unless you have a really old top with the sewn in cord that slides into the channel. Best bet, call SOR or Bestop and get a high resolution pic of the part sewn to the bikini top and go from there. How old is your soft top? If it isn't that old then I guessing you'll be fine.
on the SOR top, the plastic piece sewn to the bikini that slides into the channel on your front windshield is a square (or rectangle) cross section. the SOR "Tiger" channel accepts that square cross section which is why they say you must use it.
you may be correct in that my channel is so old as it was for a Kayline. so, my old front channel attached to my windshield is a round channel that mated to my Kayline top.
so, I am simply saying that they claim you need that square channel, but in fact the square/rectangle piece sewn into their bikinis hold just fine in my round channel.
I didn't mean to imply that the square style Tiger channel being square/rectangle cross section was a new concept. when I said "if you have an old style", I was assuming - as with these old rigs - many of us have older style tops that likely had an older style round channel and that I have successfully used a square piece in a round channel.
holly molly
Thanks, I got it now. Sorry for the confusion. My soft top is a Supertop that's only about a year old. The windshield channel cross-section is square. I should be good to go.
Thanks, guys.
What about Bestop...do they make a bikini top that would certainly be compatible with their channels???
Sure they do, I'm just considering buying a used SOR top from someone.
Everyone, correct me if I am wrong but isn't a SOR bikini top nothing more than a rebadged Bestop? Seems to me I remember reading the SOR and Bestop have a pretty good 'relationship' and that SOR has tops made for them by Bestop with the SOR brand name.
Bottom line is it looks like there are two possible windshield channels out there...Flat rectangular/square shaped or round. Flat is Bestop/SOR and round is Kayline/STC. And per Wantatlc the tops with the flat attachment fit into the round channels just fine. Seems to be you should only have a problem if you try to fit a Kayline/STC round attachment design into the Bestop/SOR flat rectangular style channel ;p
Thanks go to Wantatlc for possibly saving me from selling my family bikini top unnecessarily and it sounds like I should be able to use it with the Kayline/STC style channel!! Might have to add a couple snaps (one of the things I like about the Kayline - a snap on each end) but that should be doable eh?
