dual Battery tray FJ40
Not yet; still waiting on him to make a tray for dual Odyssey batteries (which he told me several years ago he would consider doing). He has a super good reputation though - everyone I've ever known that bought one of his trays was happy.
I'll get a picture of it later today. The stainless tray uses the stock bolt holes and stainless bolts are supplied. Mine came with a stainless/ nylon nut... I cross threaded the nylon... would rather have stainless nut and lock washer. Other than that, I'm very happy with the tray.
just returned(and they gave me a new one) a Diehard Platinum 34M today, it died at around 2.5 years. I have a real Odyssey(1700) in my 100 series, its almost 10 years old. For the most part I am going back to normal batteries like the Kirkland brand(I have one in each 45 that are 8 years old) I have another Diehard that was bought a month after the 1st in my 60.....expecting it to die soon(hopefully before 3 years)
bitching aside, I think the key to the AGM battery life is use, if you use it(like in a daily driver, like my 100) I think they last longer than say a weekend 40, even if hooked up to a battery tender. I also think the Diehards are not as good as the real Odysseys, pretty sure I will never buy one again. I would buy another Odyssey if needed
the stainless trays are great, I have a pair in my FJ60 been there for maybe 10 years
when I did duel bats in my 1982 40 10+ years ago, I did not want to move stuff around or drill holes, so I took a stock tray and made it bigger so I could fit 2 of the smaller 1200 Odyssey in it. Set up worked great, think the 1st battery lasted 6-7 years, I replaced it, then the other original died about 2 years latter, that's when I went to the single Diehard 34......like I said it lasted just 2.5 years(and I drive the 40 allot and it has a tender on it fairly often) Now it has big Kirkland marine in it. Not sure what I am going to do with the group 34 I got as a replacement today...I may put it back in the 40 or ?
this is what I had in the 40
stock tray compared to enlarged, my only welding project ever.....dont laugh. Tray is still in there
AGM true maintenance free sealed technology that is not craptastic/Optima.
The Sears DieHard version can often be had for 20% off.
I would like to find one if the old manafre dual battery holders. Installed on in my 74 FJ40 30 years ago and still works great. Does any one make them like manafre did?
Are you talking about the 4Plus dual battery tray?
it had a 1x1" angle iron at the bottom the size of two large batteries end to end then a top that was also made of 1" angle iron and the two halves bolted together batteries were solid no movement what so ever unlike a 1/4" bolt clamp that they sell now a days.
does the 4plus fit a 76 FJ40 with 2f engine with all the smog stuff on it? Or is the sor dual battery better. I do like the 4plus because the manafre the iron going around the top of the battery gets really too close to the battery terminals.
I had one, but it wouldn't fit after I moved my alternator to the passenger side for a PS swap.
