Hi, I am working on putting together a dual battery system on my 96 fzj80. In my 40, I used a simple boat switch, hooked to 2 optimas. I manage the batteries manually, yellow optimas deep cycles, I usually will run batt 1 for awhile and then switch over to batt 2 when I drive it next. This has worked for years for me with no issues whatsoever.
I have been reading some of the threads on the hellroaring, power gate, etc, etc. I would rather not spend the extra money on any of these units. My main question is will they work for what I want to do? From my research the short answer seems to be no.
What I want to do is have a dual battery system where I can choose which batt the car is pulling enerygy from. By this, I mean I want to be sure that all the accessories, radio, interior lights, etc, are all being pulled from a specific battery. My main goal is to camp with the vehicle and be able to run all the lights, radio, etc, etc. without having to worry about draining the main battery. I want to ensure that I can camp for a few days and run everything, drain the aux battery and simply start up with the main battery the morning we leave.
From what I can gather most of the systems above tell you to attach all your accessories to the 2nd aux battery? therefore you won't drain your main battery, BUT if I don't do some serious rewiring (which I won't do) than the factory stereo and interior lights will drain that main battery anyhow, correct? Again, do any of the systems allow you to choose when parked what battery you are pulling from for ALL accessories? In the end, for my needs I would like to have something that monitors both batteries when running and keeps them topped off but when parked allows you to choose what battery you are pulling from for all of the energy used in the vehicle.
Thanks for the help.
Noah
Noah
