Dual battery question
Fj moneypit
Cubic Zirconia Member
Colorado
Thinking of adding a second battery and wondering who’s done it and did you upgrade alternator and anything else? Pics of setup up if you got them. 👍🏼
I’ve had mine for years but only because I plow with my 40. I put in a 100 amp alternator. Why do you want dual batteries?
I’ll be running a winch and other accessories. Did you have to change anything else to run the 100 amp alternator? I know the amp meter can only handle 40 amps. I’ve read you need to put a fusible link with larger alternator. Not sure if this is true.
I put a 200-amp alternator in mine, and plan to have two batteries at some point. I run lots of accessories (ham radios, cb, winch, air compressor, fridge, stereo amp, etc.) and don't like my lights to dim at idle. I've been very happy with my big alternator for many years. A dual-battery system would make my fridge much more useful on long camping trips.
That’s exactly what kind of things I’ll be running. What alternator did you use? Did you have to replace any other electrical stuff to make it work? I’d like to put a 100amp. That should get me plenty more than the 40-50amp currently
Your amp meter won't be affected unless you wire all the new accessories after the amp meter. You'll be running a winch directly off the battery so
your amp meter won't see that draw. Any other toys you add can be run off a separate fuse block in the engine bay with the power source
being a direct battery lead
I added a Yeti to the back, charged by solar panels on the roof rack and wired to alternator. Gives the advantage of built-in an inverter, which I use to charge camera batteries, power video gear and MBP + Dometic Fridge
I'm running a Mean Green (modified GM alternator). 1975-1987 LANDCRUISER 4.2L - MG Industries Inc.
It's internally regulated, so I was able to take off the old external voltage regulator. One new wire to excite the Mean Green, though I did make much heavier battery, alternator, and ground cables at the same time. I replaced the ammeter in my instrument cluster with a volt meter.
I've been running dual batteries for years. Have a Hehr (since bought out by somebody else) 140 amp alt. Had to buy the matching voltage regulator. I only had a "charge" light in the dash ('74 FJ55) but added an Autometer voltmeter below the dash.
the stock bracket location is already low enough to drag around rocks and stuff, i could imagine using the drop brackets will make matter worst...
Were you drafting in AutoCad at the time? (thinking back to my first ACAD night class in '97...)
You need to put that valve cover in a museum. I haven't seen one 30 years. Clifford and Offenhauser were the only two motor "performance"
accessory manufacturers that included Land Cruiser in their catalogs .
