Drum brake 101 again
Checking the Haynes manual and my truck all around, I learned that the front wheel cyls are single-piston, while the rears are dual-piston.
Why do you suppose the fronts are only single? Wouldn't stopping power be increased if they were dual, like the rears? Would anything dangerous happen if I installed dual-piston cyls in the front?
Yeah, I can hear the "Dude, suck it up and swap to discs..." smack already, but THAT ain't happening until I actually drive the truck a while...been driving on drums for years with no scary episodes to make me swap to discs. I agree with others, it's just the PIA factor that makes a swap look great.
Mine are dual front and back.
Not sure what your year is, but I thought they had boosted drums for a while. Maybe the single is because of the booster?? Keep from locking up or something. I don't know, just rambling now...
I have a 69, and mine are single front, double rear. For a while, before I broke down and bought new ones (the old ones had been rebuilt so many times it was an exercise in futility), I was running doubles on the front also, just because it was all I had left that were serviceable.
Still, I don't recommend it. They were built that way for a reason.
All US drums were boosted after 1970. If you are running dual piston wheel cylinders in the front it is not correct for OEM. All drum system fronts were dual wheel cylinder but only single piston. Kinda suprised that works.
Were the front brakes touchy when running the dual piston cylinders?
Yeah, the only thing I can think is that the fronts would be too touchy if double-piston cylinders were used, but then again, the extra pistons would be applying pressure to the trailing end of the shoes, which shouldn't make thm touchy.
Whatever, it's my rears that are giving me fits.
