Drowning the Earth Pig
Hope Mills, NC
Well gang I'm a total idiot:bang:. Yesterday I decided to go ride down some trails around post. Well needless to say I got excited and decided to drive through a water hole that I didn't checkout. Needless to say I got stuck in deep hole. Water came into the truck and destroyed my carpet. (IDIOT) I called the guys at work and they brought a HUMMER to pull me out. The truck cranked right over and sputtered and spat and now seems to run fine. Today I took the carpet out of the truck to inspected the damage. It only took me an hour to get everything out of the truck. Wow there was some mud to get out. I cleaned from stem to stern. I used simple green and water pressure hose to get every inch cleaned. I ordered the carpet from Toyota for $412. not to bad I guess. I'll have the part on Friday and will install. I guess that will teach me not to do stupid crap. Feel the Pain.:eek:
We learn more from our mistakes
Do you h8mud yet?
Oh well, at least from what your saying nothing mechanical got screwed....
oh yeah, got any pics of the drownege...........:flipoff2:..
you are going to check the drivetrain for water etc, right?
Yup check your diffs and knuckles for water and hit the drive shafts. And just be glad you werent in a pathfinder, i toasted the ECU doing the same thing on a desolate stretch of california coastline.(who thought to put it under passenger seat in lowest locale) Is that a cdan carpet price? or doesnt spectre and/or cruiser outfitters have an entire carpet kit?
Why replace the carpet? Not cleanable?
-Spike
-Spike
I must concur. Carpet is made of high quality nylon and is highly cleanable. I have had all of mine out and cleaned it all with a hose and high-pressure nozzle. The interior of my truck has been completely removed and cleaned.My carpet was not soaked with mud. Rather, it was soaked with engine oil and transmission fluid after a rollover. Not only was the carpet soaked in oil, but the headliner and door panels were soaked as well. I took all of the above out of the truck and worked them over. I used a yard sprayer of the three-gallon type. I filled it with a mixture of one part Tide liquid detergent and two parts water. I sprayed the mix onto the carpets and headliner, soaking them well. I stood the headliner up against a wall, and hung the carpets over a 2x4 between two ladders. I washed the fabric completely with a garden hose and a high pressure nozzle until no more soap would come out. Then I re-installed them. My once oil-soaked carpets are clean and do not pick up dust. They are as good as new. I couldn't soak the headliner as much, so it still shows some staining, but it is not too bad. There are still a couple of stains on the headliner to show the truck for what is, a wheeling veteran. It looks much too clean to be a rolled over wreck! But that is what it is.
H1, H2, or H3? If it was an H1, thats not too bad. Any of the others though....
Tough luck man, glad the rig still runs good. God knows I learn best from my mistakes though, so I totally feel your pain.
Hummer
The HUMMER was a Army one (H1). That bad boy had no issues pulling me out. I've heard it all at work though. I will need to upgrade to better tires for off road and highway use though. Thanks for the advise.
