Drop Brackets or casters
Hi,
Any advice on 4plus drop brackets vs. FOR or Slee lift kits. All I want is 3-4" lift without losing on road control and comfort.
FOR
4 Plus or Slee?
Please help!
thanks,
Man Fre drop brackets were the most comfortable solutions I found and I tried several different bushings..
I would say a big deal, since I want to be comfortable during the long haul to the off-road locations.
thanks,
THanks Land Tank,
Why are your casters optional with the FOR kits? What would happen if these were not installed?
THanks Land Tank,
I can't speak for FOR but some people might already have a solution in place or prefer another solution over mine. You should do some form of correction and at that height it would mean, caster plates, drop brackets or possibly arms.
there are pros and cons to each solution and no definitive clear "best" choice. Any kind of off-roading usually negates the drop bracket option as they do hang down and catch on stuff. Arms aren't readily available for this height and while easy to install they tend to be costly. So probably the most common solution is a caster plate.
I will disagree with you on this. Arms are the BEST choice....but cost prohibits most or atleast discourages them from making said choice.
Did this forum grow a heart... usually this question is replied to with a "search is your friend" or "try a search and delete this post",,this subject has been covered quite a bit and I have read as many of the posts as I could possibly stand. From what I have read and from my limited personal experience the drop brackets do ride nice, and they do hang down if you do alot of big rocks, I would say the caster plates(bushings) would be the way to go. I have been in some deep ruts mud and snow and not had a problem the drop brackets put the rear of the arm down at the same level as the front so if the front clears no problem but if you drop over a rock and it ends up at the location of the bracket it could easily hang up and possibly cause damage to the bracket. I drug mine down a rutted road for about a hundred yards in some nasty clay mud and it didn't seem to hurt anything or slow me down. If you are not going to clear at that point under the rig it will hit the arm at the axle before it has a chance to get to the drop bracket anyway. just my .02
The blue ones 4WDToyotawhatever has on his J spring lift.
4WD Toyota Owner.:)
That's true, the Snake Racing arms are available to work with the 4" lift but as mentioned by others they are pricey indeed, plus I paid $400 just to get them shipped here!
That said, they bolt right up and are--perhaps--the only 4" control arm solution made for 80s. I do think price is a deal killer on this option compared to bushings or plates. I did the Rubicon with the Snake arms.
I ran the MAF drop bracket kit for well over two years. Rock trails are tough to do without frustration, although I did Cruise Moab just fine. Mud, ruts, sand, no problems. I would say they more or less guarantee the ride that is most like stock, because all the components and angles of the drivetrain are put back to their original position.
OK I'll bite, what arms out there are designed for a 3.5" lift?
There seem to be several people on MUD who run Christo's arms. While they are not specifically designed for 4", those who have them, have nothing but good things to say.
What are the potential ill-effects of running front arms designed for 6", on truck with only 3.5" or 4"?
