Driving my tire guy crazy.....
North GA
Taller tire vs wider tire.....which gives more resistance and less drive ability on road?
Current Cooper STT 33/12.5/15 vs getting 33/10.5/15 BFG AT's.........
These Coopers make my 3FE very unhappy on hills. Not to mention mountain climbs!
Ran 32/11.5/15's for a very short time and it wasn't too bad; but I like the height of the 33.
The wider tire offers a larger contact patch...(that segment of the tire making contact with the road) along with that comes more resistance. And it's a heavier tire...harder for the engine to rotate it.
The taller tire changes the final gear ratio (well, doesn't change it but effects it) the taller the tire, the smaller the segment of a full 360º it rotates as a correlation to how many times the ring gear in the differential makes a full 360º rotation...thereby making the gear ratio effectively "taller" as a final, on-the-road, reality.
Both adversely effect the power, but for different reasons.
the inflation level of your tires are also effects rolling resistance. Tires at 25 psi have more rolling resistance than the same tire inflated to 45 psi.
The automatic isn't helping matters either, as it's choosing when to shift as opposed to you choosing. Probably shifts early and bogs down.
4 options:
Smaller tires
Learn to accept it
Change Ring and Pinion gears in front and rear diff
Add more power (v8)
the skinnier tire will have less rolling resistance so should drive easier and steer easier. Probably lighter as well so that will help your accell and braking. On road drive ability I wouldn't expect much negative impacts from the skinnier tire. Sure the wider has more contact area but heavier too so maybe a near moot point. Off road drive ability... Well that opens up the wide vs skinny debate I'm not touching ;)
Wide will float. Skinny sinks down to the hard pack and on and on and on
We have the 33x10.5 mud terrains on the 92 and we down-shift all the time. I usually (almost always) manually down-shift when going up hills. Anyway, I'm sure the 12.5's will slow you down a bit more than the 10.5's due to the increased weight and surface area. How much? probably not noticeable. If I was really wanting to help the situation I would gear up to at least 4.88's. Remember you are driving a vehicle that weighs over 5K and is powered by the 155hp 3FE. Down-shifting will be necessary.
You really need to try a mountain climb like where Trapper lives, lets say highway 550 from Silverton to Ouray. Our 3FE with a family of 4, a dog, and a loaded military trailer has to have the transfer case (w/7pin mod) in low just to make that climb. 25mph is about all it will do at 3k rpm's.
...You really need to try a mountain climb like where Trapper lives, lets say highway 550 from Silverton to Ouray. Our 3FE with a family of 4, a dog, and a loaded military trailer has to have the transfer case (w/7pin mod) in low just to make that climb. 25mph is about all it will do at 3k rpm's.
Yeah, hauling that much with a 3FE, on that road, would be a nightmare. Any of the passes around here would present a challenge and slow going for that load/power combo.
So moving from my STT 33/12.5/15's to BFG AT 33/10.5/15's isn't really going to yield any positive power increases.....just maybe steering and drivability?
I had 32/11.5/15's in Flaken Wild Peaks (not really aggressive looking). They seemed pretty tame. And I didn't seem to have as much resistance climbing.
Maybe an MT in 32's!? Trying to find the sweet spot :rolleyes:
Weight is a factor. Look up the weight of each of those tires you're dealing with.
Rule of thumb is 1 lb of unsprung weight = 10 lbs of static weight.
So if each tire is 10 lbs heavier, that's like carrying another 400lbs in the truck.
There is a 9lb difference.....hence 360lbs!
I was thinking of it as only 36lbs more :doh:
Makes sense because it FEELS like I'm pulling a lot more weight!
You can always regear it ;)
Eventually I am getting 33's.
But not until I regear it first. For myself and where I live I won't even consider bigger tires before that is done.
Searching around, 4.88's are about $1000 in parts alone. I can do the work myself so labor is just my time.
I would like to install lockers at some point and found a complete 3rd for the front with 4.88's and an ARB for $1500
I'll probably go that route for the front as the price is reasonable.
Not bad so long as the install is fresh. Otherwise you should verify the gear setup to make sure they're good - which can put you right back in the same price bracket of doing your own gear/ARB install!
Yep, read that. Very informative for sure.
I'm currently trying to decide between BFG AT 33/10.5/15 and Wild Country MTX 32/11.5/15.
Well, to my mind, there is no appreciable difference between those two as it relates to your truck's ability to turn them. At that point the decision becomes price vs. durability/longevity.
In case you haven't seen this (at the risk of wading into the wide vs skinny debate):
http://www.expeditionswest.com/research/white_papers/tire_selection_rev1.html
The relationship between adhesion and friction forces isn't completely understood. Claiming its always dynamic -which is certainly false - it's almost always static even offroad gives me pause. In reality there's a bit of everything going on and I'd be careful relying on the science part of the article.
If higher contact pressure is the goal (which is the basis for claiming narrow tires provide better traction), then you would not air down tires. That does exactly the opposite.
I think it's fair to say that tire choice is dependent on terrain. If you want to go the furthest down the hardest trail, I'll take taller and wider. I've never found myself wishing I had greater ground pressure.
