Driveshaft
Boulder Creek, CA
Hello,
I just finished installing a 4" Hellcreek spring kit, with JT anti-inversion shackles. The issue at hand is: during accel at aprox 45mph there is a prounounced vibration that directly relates to speed and load applied to the drivetrain. This vibration also appears during deceleration. The driveshat has a fairly sharp angle so I am wondering if this might be "it".
Has anyone used a "84 FJ-60 CV front driveshaft? If so what are the mods required? I have a fab/machine shop so cutting turning welding ect. is available.
I'm no expert by any means but anytime you lift a vehicle with a suspension lift you change the driveline angle etc which more often than not leads to vibration issues, driveshaft length issues, etc.
I'm sure they're are plenty of threads on here about this very subject and what people did to correct the issue. I've seen everything from shimming the axles to fix the angle of the driveshaft to dropping down the drivetrain somehow to getting real creative with u-joints etc.
In addition to the vibration is it safe to assume that you also checked your driveshaft lengths and brake line lengths?
BTW, the lift looks nice :)
Cannot see your pic...
What is the condition of your drive shaft and joints? When was the last time they were greased?
Often, when installing a lift and increasing the angle of operation on the ujoints you find that they are not in as good a condition as originally thought.
You coupld just install a 4* shim inbetween the rear axle and leaf springs and see what happens....
Steve,
I just went out and looked at the driveline more closely, the rear pinon is tilted up about 5deg. The xfer flange and the input flange are not parallel. The difference is quite evident. The driveshaft was greased about 2 months ago. I think I will regrease and inspect more closely. Any info about the '84 FJ-60 install?
eric
p.s. pics posted to original post
Might just be the camera angle, but in the second pic it looks like your driveshaft is about a spline off. Make sure the yokes are in phase.
Ed
Ding, ding, ding,
I went back out and looked at the driveshaft, indeed, the universals are misaligned. I was rolling the axle/wheels around when i was trying to get the spring pins aligned with the axle. I guess when I was rocking the wheel back and forth the driveshaft pulled out enough to reindex when I rolled the wheel. Who wadda figgered, thanks Ed good eye! Still interested in the '60 driveshaft refit though!
Thanks to all who took the time to look and offer ideas!
eric
Otterav said:
Ding, ding, ding,
eric
Should be fine with any cv from the front of a pre ifs minitruck as well. you may have to drill new flane holes, but the tube size is similar. You should be able to cut the tube off the couble cardain on the shaft and also remove the end from the current shaft you have. put the new end into your current shaft. Your current shaft will have to be shortened some to make up for the length of the double cardain, but that's a good thing because you don't have to buy any new pieces of tube. I made these for the front and rear of my soa 40. I got both fronts for $25 each from an offroad shop who had about 5 sitting under a workbench. I welded mine up myself with lots of measuring and spent a lot of time making sure they were straight, also make sure you have an experience welder weld them to make sure that the heat wont warp.
You will also have to shim the rear to point the output directly at the second joint in the double cardain. Also you may need to make a new fill plug higher in the rear to keep the pinion oiled.
good luck
good luck
Howdy! Good info, especially about the filler plug. Easy to overlook that. Pinion bearings tend to have a longer life when they are properly lubricated. Stock position has gear oil up to bottom of bearing. Mine takes a lot more oil now, because some of it goes out into the axle tubes. Keeps the axle bearings well oiled and cooled! John
Unfortunately I know from experience :doh:
