driveshaft vibration concern
97 LX450 (stock) with 300K on the clock. While on the hoist for new tires, we decided the u-joints were due for replacement. Surprisingly, there was no vibration at any speed. Ordered u-joints and had them replaced yesterday by a shop familiar with 4x4s but not fj80s. Know i'm getting a vibration that increases with speed and buzzes pretty good at 70-75mph. Before i return to the shop i'm hoping for some advice as to where we should start. What could we have done to cause this by only replacing 4 u-joints? Thank you in advance for the advice and sharing your knowledge...
They did not. I,m in a rural area of Michigan and it's a small shop without that capability. The mech said the u-joints would not change the balance of the driveshaft. Is this not true?
Short answer: I don't know.
However, I keep reading threads about Gus chasing drivetrain vibrations and unbalanced driveshafts are not an uncommon cause. All other things being equal it leads me to think unbalanced drive shaft.
Also, are the zerk fittings oriented correctly? On my truck they were 180° out of phase when I bought it - made greasing them nearly impossible. That and the zerk fittings on the u-joints themselves were missing - which made greasing them even more impossible :confused:
vv @inkpot is correct of course vv By 180° out of phase I mean backwards with regards to where FSM says the zerk fittings should be. My bad.
Appreciate the reply. Zircs are good. I watched him grease them. I'm wondering if he bent one of the yokes during the old u-joint removal. Two of them were difficult to remove and he hammered on the yokes pretty hard. Could this cause the vibration? My thought is a bent yoke may create a slight misalignment...
I have not been greasing the driveshaft for fear of over-greasing. After manipulating the shaft quite a bit yesterday, should we have greased it? Would that have any effect?
Good idea to grease the shaft on assembly. You said you got new tires, are you sure they all balanced properly? I've got a driveline vibration I'm chasing down too. Have replaced rear u joints. working on front shaft now.
Vibration after new tires and u-joints? After checking the phase of the shaft (which you did), I'd check the tire balance again.
We discovered the worn u-joints while installing the new tires. Had to order the parts. Drove on the new tires for a week before installing the u-joints and everything was smooth as glass. 99% certainty it's related to u-joint/yokes/driveshaft. I'll be taking it in next week and repost the results. Thanks all for the input. This forum is great! (Imagine if the Ford Pinto would've had a forum...)
Don't fix what ain't broke........
Pull the front drive shaft and rotate it 180 degrees. Drive it. See if the vibration goes away. If it does, it's fixed. If it doesn't , do the same with the rear drive shaft. This is of course assuming that he didn't mark everything. I marked my front drive shaft but then proceeded to clean off the marks (fingernail polish). Didn't make that mistake on the rear drive shaft. I had to rotate my front shaft and then it was all better.
