I'm going to be under the rig this weekend and want to lube the driveshafts because I haven't added any grease in the two years I've owned it.
I read the cautions against over-doing it causing wear/leaks etc.
I would like your thoughts on this tactic:
I plan to add several pumps of grease then pull the zirk off covering the fitting with some tape and paper towel. Then I'd do a short drive on dry pavement maybe a bit of one wheel at a time over a curb or speed bump. Then I'd wipe off any grease that squirted out and reinstall the zirk.
Will this
A) cause problems and do no good
B) do neither harm nor good
C) might do some good and won't cause any problems
TIA
Will this
TIA
