Driveshaft lenthening
so i cann a driveshaft place today for a quote to get my driveshaft lenthened and the guy said they cant lenthen CV driveshafts... i wondering if someone can tell me why? its a CV DS out of a early 80s toyota. also how much does it usually cost to lenthen it about 3 inches
what happened is, you called a shop that's too lazy to disassemble the CV and do the work....
Shops around here all end up charging an arm/leg to disassemble the CV itself, lengthen the tube, and reasemble....
http://www.4x4wire.com/toyota/tech/cvmod/ is the disassembly process...once that's done, and you are SURE your measurements are correct, take in the tube to be replaced with a longer one...
Also, some shops only have SAE tubing, oddly....Toyota stuff can be weird for them. I've had all my recent shaft work done thru http://www.highangledriveline.com with no problems.
I have had two FJ60 front driveshafts with the double cardan joint lengthened within the last year and they did not have to disassemble the CV. They did a good job and balanced well so I am not sure if they did it incorrectly or possibly disassembly of the CV is not required for lengthening by the method they use. I used Big Moe's in Birmningham 205-780-6206. It cost approx $125 each which included a new tube on each. Shortening with spin balance is around $70.
i recently had a normal shaft done in Moab in an emergency for $110.. the guy said he had to machine down the yokes and what not to adapt SAE Tubing.. but it would be stronger than before and i shoulding twist it up like i did the last one..
My driveshatf guy has never taken a DC apart to lengthen a shaft. He did about four dozen shafts for me before I had to quit using him (for complete unrelated reasons). Every one was perfect and required no weights. Well, one had to be tweaked a little because it was a few thousands out of tolarance, but that took him just a few extra minutes.
I have all of my shafts fitted with larger diameter, thicker wall section SAE tubing which fits over the little section of original Toyota tube that we leave on there to help locate things.
Mark...
