Driver's side suspension noise
Beaverton, Oregon
Hello,
I've been chasing a noise (heard in video below) for a month. The noise is heard as a click, snap or pop at the end of the video. It actually sounds like the spring loops are snapping together. It sounds like a metal on metal pop/snap. You can feel it in your left foot under the floorboard. The sound only happens when the suspension is being torqued or under stress....like turning right, uphill. You can't feel it in the steering wheel and you can't make the noise happen turning the wheel lock to lock, parked. I have a Slee 4" lift with Icon shocks. It's not the sway bar bushings, control arm bushings, pan hard bushings or shocks. The steering arms and tie rod/ends are new. I had an alignment right before this started. Is it possible they made an adjustment that messed up how the spring is seating at the top of the coil? I am open to any suggestions. I've tried everything but swapping springs side to side and that's happening next Tuesday morning to see if the noise moves.
I'm headed to the alignment shop today to show them the video and see what they think. Thank you for any advice that might help solving this issue.
Bart
The video does not offer much that I can detect although I did hear something. Unless something is cracked the noise must be coming from a loose suspension bolt or worn bushing. I have had a few different sets of springs and never a noise caused by springs. Have you disconnected the shocks and checked them out?
Have you checked that suspension fasteners are torqued to spec, with a torque wrench? Some of them have locking bumps, so always turn the fastener (nut or bolt) with the washer, not the one with the flange.
Thanks. Yes. Everything has been torqued to specifications. Update....Tightened up the driver's side motor mount a little and the rubber puck shredded. I was initially able to turn the motor mount nut easily with a crescent wrench. I've ordered a new set of rubber pucks. I'll know if this was the problem next week.
I do have a V8 swapped into the Land Cruiser. So, Advanced Adapters motor mount pucks have only lasted me 3 1/2 years. That's not good. It does get hot as hell under the hood but I expected these mounts to have lasted longer.
So, I took the pandard/track bar off and found this today. The bushing has failed on the driver's side. Do you guys think this could be causing the snapping noise heard in the video and what I am feeling in my left foot? The hole looks like it's beginning to oval out too. This bushing only has 16k miles on it.
Do you guys think this is the smoking gun? Does anyone know if Toyota track bar bushings can be pressed into Slee's adjustable front track bar?
I can't see where the bushing in the photo has failed honestly. It just looks a little dirty as far as I can't tell.
I'm quite sure that OEM bushings can not be used in that track bar. Those poly bushings are cheap and easy to replace and readily available.
The metal has been chipped off on the lower left of the bolt sleeve in the center of the bushing. The bushing has play in it and is somewhat squishy now.
How did you check the torque before you removed it? Re-torqued it? The only way I have seen bushings sleeves get elongated like that is if the bolts were loose. It is difficult to see if the metal of the sleeve was worn off, or cracked off the end of the sleeve if the bolt was loose. Even with that piece missing, if the bolt was properly torqued, the sleeve will stay in position.
Thank you for the response. I set the torque wrench to 127lbs or a little greater and put it on the bolt and got an immediate click when I applied force. It was not loose. The bushing had some play to it and was not as stiff as it was new. I think this play in the bushing created the ability for the bolt to move. Do you know if Toyota OEM bushings can be placed in your front adjustable track bar? I have not got a diffinitive answer on this.
Now that the sleeve is ovaled out, it can move and needs to be replaced.
Thank you.
The sleeve can not move if it was torqued and the holes on the frame side are not elongated, doesn't matter if the bushing urethane moves. We were informed by the manufacturer of the rods that the eyelets are sized to match factory bushings, but we have never actually installed a set of OE bushings into those rods, so I can not verify that.
Well, somehow the hole got elongated and it needs to be corrected. I wish I could say, hey, it was loose and that was the issue but I can't. I'm am going to attempt to press OEM bushings into the bar. I'll post up what happens and if this fixes the noise/snap issue.
There should be a part number on the bushing. Google that number. Daystar is one company that comes to mind that sells poly anything you can think of.
Thanks..I tried google before I asked. I came up with nothing. I'm going to try Toyota bushings first. I'll go to daystar next if that doesn't work. Thanks for the suggestion.
