Driver's side suspension noise
I also believe I found the source of my noise. The welded bar above the front panhard is crashing into my oil pan when there's body roll. Swapped V8 issues. So, I hope to fix this problem with $2 worth of washers.
:clap:
Well, providing clearance between the stabilizer bar and the motor did not fix my popping noise issue.
Here is what I have ruled out so far -
I am going to try some OME 5MM spacers to pad the front springs now. Some say that fixes spring noise and maybe that's what I have got.
New video.....same noise. The noise starts around the 3 minute mark. I am going to take the bump stop cone out and investigate. The sound sounds like it's coming from the top of the spring bracket. It does not appear that the bump stop is binding the spring.
I have been told that no way can a spring be making the noise heard in the video. Well, there's always a first time.
Here's is further evidence. Has anyone ever seen a spring wear like this? The wear line goes back at least 4".
Looks like you've got coil bind. But I don't remember you bottoming the suspension out in your video. I don't know enough about these suspension's yet but are you sure the springs are installed correctly? Is there a wear pad or rubber insulator that maybe came out or wore out? Is your top spring mount cracked or loose?
The spring mount is not cracked or loose. I have no insulating rubber pad above the springs. I have ordered some 5MM OME acrylic spacers to see if that fixes the issue. I have Slee 4" springs and ICON 2.5 shocks. I was told my shocks are too long......can remove springs with a little force at full droop on a lift. I had been running this set up for over a year without issue. I am unsure what caused the problem. Thank you for your reply.
A little off topic, but I assume you're using a Go pro. What model and how are you mounting it to the truck?
I have been using a GoPro and a Polaroid Cube. I have been zip tieing the GoPro here and there. The Polaroid Cube has an integral magnet. I can stick the Cube any where there is metal. The last video was shot using the Cube and double sided tape stuck under the fender flare. The Cube size is only about an inch square.
I've never watched a 80 series suspension in action before but it looks like the rear( as in towards the back of the vehicle) of your upper spring mount is moving/flexing more than the front (where your shock reservoir is attached). Do you have any uneven tire wear?
I don't think you have coil bind based off the top 2 coils being close together the OE coils has the same type of winding to get the desired end finish. The coil insulator ideally should be installed, not having it will usually in some cases cause a squeeking noise, not usually a knock and will wear the metal on the coil tower eventually. How close is the bolt mounting the res on the inside of the coil tower to the coil, is it possible when the coils moves it's hitting the bolt? On the last video, the hose to the res moves up and down and the metal connection is going under a bit of rubber, but what is on the other side, may possibly be hitting somewhere on the other side? I hope that helps!
Interesting observation and one I hadn't noticed. Thank you. I am unsure about the bolt and what's going on there. I plan to take the shock tower completely apart this week and install a 5MM urethane spacer. I'll post up what I find. The noise is very distracting driving off road. It's just weird that this noise started out of no where. I've had this same setup for over a year and nothing has changed.
The metal connection that goes under the rubber flap is directly connected to the shock absorber and there is plenty of clearance around the shock. Once I get it all apart maybe I'll see some signs of wear on the head of that bolt.
Binding relating to springs is when the all the coils are compressed to the point that there is no more compression left in the spring at all and it is trying to compress the metal, the top or bottom few coils touching is nothing out of the ordinary.
Are you sure the top spring support is not cracked? Haveyou checked the chassis especially where the steering box bolts on? It appears to have quite a bit of movement, but I've never seen footage of a 80 top spring support in action before so it is hard to tell.
Maybe film the other side to see if it moves the same amount?
Steering box mount and bolts are good. I'll be taking the spring tower apart and doing a full investigation soon. I am leaning towards that bolt under the res bracket or the bolt in back (both support the bump stop cone) coming into contact with the spring when the suspension is flexing being the problem.
