Driver's side inner brake hose help please.
Indiana
Anyone have any advice they can pass my way to help me change out this inner brake hose that runs to the axl on the driver's side? I was driving around yesterday and my brakes started acting funky. Pulled over into a parking lot and noticed my brake resivoir went from "Max" to "Min" rather quickly. After getting her back home and into the garage, I noticed bubbles on the brake hose running to the axl, and slow drip of brake fluid on the bottom center of the hose, when the vehicle is turned on and running. After I swap this hose out, will I need to bleed out all four corners, or just the side I changed the lines out on?
Yes, bleed the whole system including the proportioning valve. Flush and bleeding needs to be done every 2 years or so and especially if the system has been breached.
Thanks man! Any advice on getting this inner hose out? I noticed the driver's side hose is routed differently than the passenger side one.
If one hose has failed all the others are most likely in similar condition. Replace them all and bleed the entire system including the LSPV. Trying to take the cheap route when it comes to brakes just doesn't make sense.
nothing special to changing them out, just get a good set of line wrenches to crack them loose. i would replace all of the soft lines and in the front the short hard lines that go out to the caliper as well. bleed everything out and call it a day
Buy the Toyota hoses listed above because they come with a tab on them that keeps them from rotating when tightening. If you buy aftermarket, they will start to spin when tightening and will end up in a weird orientation or have a twist in the hose and that's not good.
Thanks for posting these. New brake hoses on all 4 corners is on the spring "to do" list. I just haven't decided if I'm going to use OEM or go stainless steel. I'm just going fix the leaking one right now b/c she is going in the garage comes November.
Do the stainless steel hoses have the tabs on them?
Do them all now and bleed all once instead of having to do or pay labor twice or more.
I'm just going to replace the leaking line right now. I'm going to be storing her here comes November. New lines, brake pads, rotors, calipers, and 2 inch lift are on the spring "to do" list.
I bought the SS hoses from Slee and they do NOT have the tabs. That's why I'm very aware.
Slee hoses are very good and work well, but takes a bit more fiddling. I've done LOTS of brakes and am used to doing things the hard way....
If you're planning on doing a lift, get the longer hoses NOW and do them ALL so you don't have to do it all later. I ran the longer SS hoses on mine for 3 years before I finally got my lift kit installed.
So let me ask you this. I'm at stock height right now. And as I said, I plan to do a 2 inch Ironman or 2 inch OME lift come spring. If I put the extended hoses on now will it be a problem?
Disregard my last post. You beat me to the punch lol.
When it came time to install my springs and shocks, I didn't have to do brake lines, so I was ahead of the game. I already knew what I wanted (No one had researched and documented the longer Toyota lines at that time) so I did what was best then.
When I installed the lift, it took about 8 hours in my slightly sloped driveway with tall stands and jacks, all by myself, so I didn't need anyone to help me bleed brakes!
If I only plan on driving my Cruiser April to November, is it worth it to go the stainless steel route? She is not going to be a trail rig either.
Since the Toyota ones are available in the longer format, I would say no.
The second half of that question may be which one is less expensive and what crap am I willing to deal with for the price difference?
I'm guessing the SS lines will be less expensive than the longer Toyota lines.
True
IMO, the SS braided lines are a marketing gimmick. I wouldn't use them on a street truck or a trail truck.
You will find that OEM parts are almost always superior in quality to anything in the aftermarket, regardless of the hype. There are VERY few exceptions to this.
^^^This^^^. I fell for the hype and bought a set of the aftermarket SS Braided brake lines/hoses maybe 15+ years ago but once I had them in my hands felt they were of a lower quality construction compared to the Toyota lines. Never installed them. FWIW.
