driver's door power window
Would anyone happen to know where I can get a power window motor driver's side for a 1992 L.C. 80 series? Are any other toyota PW motors compatable?
Thanks for your help,
You have probably checked, but if you haven't, and you have a slow power window, the problem may be the window channel, which oxidizes and becomes stiff. I tried lubing and all the other ideas which were only temporary - replacing the channel solved the problem. The power window motors are extremely strong and durable so that may not be your problem, IF slow windows are what is driving you to ask this question.
It appears when I press the switch for the drivers side window its getting close to 12 volts of power however the window is permanently stuck in the down position,making me think the motors gone.Anyone had a similar problem?
thanks for your help
I have one from a 93, if they are compatible, let me know and i will give ya a good deal on it.
K
Before you spend time and $$
Remove the inside door panel, there will be screws in the handle, one at the inside door open location and lastly you will need to flip your arm rest out to remove the screw south of your window controls.
Once all the screws are removed you may proceed to pull away the panel. With the panel removed you should be able to remove the 2-3 bolts holding the window motor. Once the motor is loose unplug the wiring harness.
Take the motor and try it at your bench or via wires to a 12volt source.
If it still does not work take it apart and re-grease the insides while checking your contacts.
While you have everything apart take the time to clean/grease /replace parts as needed. Oh and give the door contacts a good cleaning or change the drivers contacts with a lesser used set.
If you can get a grip on some of the glass without breaking the window, grab it and pull up while you hit the power window switch for up. If it's the seal, the window will come up with your assistance.
