Driver side exterior mirror part
california
Does anybody have a particular seller/Vendor online? To purchase a new OEM replacement mirror assembly. I have already done plenty of searching with numerous eBay sellers. Prices vary dependent on whether it comes from Japan or some other overseas location, or from the US. I am aware that there are many authentic looking fake OEM Toyota parts sold online. That are reproduced & packaged so well it is difficult to tell whether or not it is a fake. Asl me how I know , I already purchased what I believed to be OEM mirror 8 months ago. If anybody has a specific (reliable) seller/vendor would appreciate info?
Marc
The OEM side mirrors for US spec 80 Series have been discontinued by Toyota for awhile (years). You might try Japan4x4, NENGUN, Yoshiparts, or IMPEX to see if they can find one in Japan. Fleabay has a few OEM side mirrors for sale but very high prices.
Marc
I picked up two sets of OEM mirrors used. Both were in excellent shape and cost about the same as the new chinese knockoffs.
From where?
Had this one for several years. No issues.
Electric Side Mirror - Passenger Side / Right - FJ80 1991-1998 - https://cruisercorps.com/collections/80-series-shop-all/products/electric-side-mirror-passenger-side-right-fj80
Out of curiosity, why is wrong with your mirror? IMO, the floppy mirror fix and shaky mirror fix from @Delta VS and @Outsane go along way. In fact, I think that with these products, the 30 year old mirror performs better than the new one mentioned above.
The OEM toyota mirror that I purchased (ebay) 8 months ago. The motorized mirror function does not (articulate) perform like the original, and there is now a distinct wind noise emanating from that location of the door where the mirror is mounted.
Marc
Marc
Is the bottom cap still there?
Looks like this
Hmm double check the runner triangle grommet is there and the three m6 bolts are snug.
I'll check that out once I get the chance later this week.
I was able to check the triangle grommet or foam gasket. The triangle gasket was in place, in addition to that I added a additional thin weather stripping gasket around the triangle shape area of the mirror. Reinstalled & snug down the three bolts. The wind noise is still there?
Maybe its your door seal then.. The tweater mount should not effect the out seal at all.
As far as I can tell..
It's been a minute, circling back regarding my wind noise issue. I removed the exterior mirror and packed in some foam , to the interior plastic trim cover piece. The plastic trim piece that covers the bolts through the door frame. There was some OEM(old) foam in there already, I left it in place and added some additional. The wind noise still persists though it does seem a little quieter?. Not really sure what else could be corrected at this point. I can just play the music louder😉
Or buy another mirror and try again☹️
Marc
What do you mean by replacement? Like taking it apart to insatall parts? Or replacing thie whole thing altogether? It's pretty simple. Remove the triangle trim on the inside of the door. The clip is stiff and is easy to break the trim piece. Behind that are 3 bolts. There is one more little reatianer on the rubber gasket thingy, then the whole mirror assembley will come off. The wires are pretty easy to figure out.
To disassemble the mirror itself, remove the screw in the bottom and the mirror will come out of the housing (youll probably have to work it out), exposing 4 more screws. Take those out and one more hidden behind the pivot of the post, and the whole thing will be apart.
Hope this makes sense and is correct, this is just from memory, so I could be a little off.
