Driveline lash
Nardulli
GOLD Star
St Louis, MO
As I’m new to these rigs, I don’t know what’s “normal” regarding lash.
When shifting between drive and reverse there is noticeable clunk. During normal driving, there is no noticeable clunk. On throttle, off throttle- nothing. Seems normal.
I have some records from previous owner, but no mention of any driveline work. The T-case appears to have been worked on - RTV on the mating surfaces.
There was some slop in both drive shafts - u joint wear and some surprising slip joint wear - so I replaced both with OEM parts. (Surprisingly affordable). I don’t think PO knew there were zirk fittings on the slip joints.
So- what say the forum elders on this topic?
Do a search and you will find a lot about this topic on the forum. CV spline/drive flange wear is another common culprit but some people put a lot of calories into resolution and still have some play. @2001LC has some videos showing how much play he deems excessive.
New hub flange
Badly worn splines
Outer Axle of FDS (AKA CV) splines
New FDS
Badly worn down FDS
CV axle/flange spline wear, diff bushings and front diff wear/excessive play were all partly to blame on mine.
