Drive train whine
Well I went to a local driveline shop and the guy said it sounds like front pinion bearing. They get $350 to set it up. I have to take the 3rd out and drop it off. Doesn't include set up kit.
I also asked him about installing marlin transfer case gears and fixing two muckered up studs on my front output. He said $500 dropping it off and they take out the case, etc. How much time do these gears take to install?
These prices sound about right?
*****Do I still lock the diffs when I completely remove the 3rd?****
^^^^ I never did any work to the diff. I changed the lube one more time and the noise is much quiter. After speaking with other cruiser heads and taking them for a ride they seemed to think I was crazy. So I decided to wait for the noise to get louder in the future. I dont put more than 4k miles a yr on the 80.
It sounds we're in the same boat.....lol. I changed lube front, rear and xcase, along with new ujoints and I swear I still hear it. It drives me crazy, I hate weird sounds but everyone swears its not that bad.
I have the same issue as well -- a really distinct(a very harmonic 'hooooo') whining sound starting at lower speeds like 35 and carrying up to 70-75, goes away down grades where I can coast, loudest during acceleration. It completely quieted down when I pulled the front DS but my caster is already somewhat out of spec and with only RWD and the Wyoming winds it really wanted to wander all over the place on the highway, not fun.
Going off of what someone said earlier about a worn drive flange causing a noise and tearing up inner axle seals I'm going to swap a spare brand new drive flange tomorrow with the one I have on the side of mine that likes to eat axle seals. Not sure how worn out it could possibly be because my 80 only has 131k on it at the moment but I'll update tomorrow evening.
If the drive flange doesn't fix it then I'll swap the other side also. If there is no fix there I'm going to try running my front DS in-phase rather than the oem out of phase configuration and see what that does. I know scrowley has a DC front shaft but how about everyone else here who has an OEM front? Are you running in phase or out of phase?
I ended up installing 529 diff gear s and the. Whine is gone. Figured I would update from my original post. Also the own gears all looked very good. Prob a pre load issue originally
That's pretty clearly a bad pinion bearing.
Same as on mine that I'm too lazy/cheap to deal with. :meh:
That's been at the back of my mind for a while as well but I've been thinking I want to rule out everything else possible before I come to the conclusion of the pinion bearing. Would you think it's more likely the inner or outer pinion bearing? ...or is there any way to tell before replacing one of them?
If you're replacing one you should replace both, no sense in doing just one.
I most likely would do both as long as it's out but just was thinking out loud for my own sake.
Update- I replaced a drive flange today and the noise is still just as loud, going to put my DS to the in phase config and see if that helps. I am leaning toward the bearings but I'm thinking it could partly be exaggerated by other components in the driveline perhaps?
Well I drained front diff. birf soup. Getting parts from Beno to fix this soon. With replacing gear oil seems to have quieted some - maybe. Also appear to have a slightly loose u joint on the front. Maybe this will fix. Gonna work more on this this coming weekend. At least no metal shavings on magnet when drained.
