Was driving the 80 yesterday and noticed a weird clunk at low speed around 10 mph, kind of a ker-clunk and then it go's a way seams to happen with a slight turn or light braking, but if I try to make it happen it won't but you cant drive a block with out it happening. It seem to come form the transfer case or front drive shaft , front shaft is new and checked out fine, front axle is newly rebuilt hub to hub including new gears & shafts. I pulled the fount drive shaft put the fount end on jack all seams fine put it back on the ground hit the center lock went for a drive still doing it. I was thinking when I get back at it today to put the front DS back in and pull the rear DS to try to isolate noise. Any help or idea's from the Gurus be greatly appreciated.
PS I wheeled the piss out of it at Hollister hills last weekend
