Drive Shaft U-Joint Replacement
Olathe, KS
Can anyone recommend a shop near Olathe (KC is fine too) that does drive shaft u-joint replacements? I thought Napa could do it, but apparently they no longer do that.
have you tried inland truck parts? they used to shorten or lenthen driveshafts when i did conversions.. they can prob install and balance.
they're not that hard with a press or a good vise.. you can damage the yolks if your not familar with them.. maybe as simple as purchasing an arbor press instead of a hydraulic press. if you need to "tool up"
I borrowed the press from advanced last time I did one.
