Hopeing you Guys might be able to help on this. I got a vibration in my driveline, especially when backing out of the pedal at speed. Checked the u joints, a little loose, and checked the Search here also. Unless I missed something, with my T/C- rear pinion pointing at each other within 2-3 degress ( which it does ), I guess I need to run a CV joint at the t/c instead of the regular 2 joint shaft like I have now. From the Search I gathered that I needed a Front d/s out of a straight axle mini truck to get the cv. Picked one up ( '88 model ) but the bolt patteren on the flanges are way to small. My rear end has a drive flange with 2 bolt patterens, Cruiser on one, and the other is a little larger. So for right now I put 2 new u joints in , but what would be the correct way to do this drive line? Many thanks, Al
