Thanks for the input. I turned my front DS so that the yoke is forward. Per the FSM.
I went by the local LandCruiser shop to look things over and between all models of LC’s and Tacos the drive shafts where pointing many different ways. Who would know which way to position your DS? Not sure of the rationale from the FSM is simply to clear the sway bar?
On most the 40’s and 60’s the slip joints were at the TC. There was one Troopy with the slip joints forward. Most of the 80’s had the slip joints forward.
So, I’m sure if it matters in the long run?
devo
As said earlier, no discernible difference from running it either way save for sway bar clearance. On my current 80 the slip is at the t case. It would likely rub if not for the sway bar drop blocks.Yes, I agree with you @subzali. So again, is the only reason for the slip point to be forward is to clear the sway bar on the 80?
devo
