So I replaced my fuel pump about 2 weeks ago and did an oil change right afterwards.
Today, I check my oil and it’s about a quarter of the way from full already. So I’ve searched the forums trying to figure out things to check and whatnot. Here’s my known issues:
1. I’m 95% sure I have a oil pan gasket leak. The entire underside of the vehicle has a coating of sludge. And I have follow the leak to thinking that’s the location. However it will go days and days without leaving a drip on the ground - it seems to only leak while driving and likes to spray the undercarriage.
2. Lately I am smelling oil burning slightly in the cab while driving. I checked the tailpipe and it’s only got residue in the pipe, and it’s less than my wife’s 2015 Subaru. From other threads, it sounds like I should check my PCV valve and spark plugs as well?
3. Also, I am attaching a picture I just took - why is this wet here?
Any suggestions or thoughts? I’d like to find out if I’m just losing oil at the oil pan gasket and that’s the smoke im smelling with whatever it is running into - or is it another issue entirely on top of the oil pan gasket leak.
