Cruiserdrew
On the way there
A weird observation, but...
I am renewing a set of FJ60 rear springs to use in my 71 40 rebuild, and I got these new perches and plates from Roughstuff. I also got some 7/16 spring pins at Napa to put the springs back together, and the head is just the right size for the perch. The existing hole in each pring leaf is just a hair under 7/16. 3/8 goes through easily. So I got a 7/16 bit to enlarge the holes. It is nearly impossible to do this. The metal must be extremely hard as the bit does not want to cut it. Any tips here? I spent a few hours getting the holes done and ruined the drill bit.
I also added a leaf from the front packs to beef up the rear just a bit. I did find that the shortest leaf was cracked and I replaced it with the short leaf from the front pack, so now I have a frankenspring to use in the rear. It took about 3 hours to pull the pack apart, wire brush, drill, and spray paint. It would be cheaper to go to work and order springs from Alcan!
