Drawer & Sleeping Platform(just finished)
Capo Beach, CA
Long time lurker, first time posting. I just finished a set of drawers/sleeping platform and wanted to share here on the forum since I got nearly all the ideas from searching this forum for posts. Here are a few details:
- Final dimensions are 43"w x 40"l x 13"h
- 3/4 inch AC plywood for box and drawer fronts
- 1/2 inch AC plywood for drawer boxes
- Drawer cavity was 30" deep
- I used 28" drawer slides from Amazon with a 250lb weight rating - click here
- Drawer handles were also purchased from Amazon - click here
- tie downs were just something I picked up at Lowes, same with the front compartment
- Carpet is $20 roll at Lowes - indoor outdoor polyester stuff - It's the only thing I am concerned about the durability.
- I used 3M spray glue and staples to hold the carpet down, not sure I used the glue correctly because it didn't seem to hold very well. Staples did the trick.
I think the total cost was about $300
Let me know what you think and if you have questions!
Nice work...... kudos!
Well Done!
Same carpet I used on my drawer build, it's been a couple years and still going strong. I used carpet glue and a trowel to put mine down.
Great job! How are you planning to sleep on it? Do you have an extension that goes over the back seats?
I was going to buy a sheet of plywood today to make the extension. I have enough carpet left over for that as well.
I was hoping to find a good foam mattress, does anyone have a suggestion. Or, is an air mattress best?
Go to a hobby store and they will cut you a piece to size. The Hobby Lobby in Wilmington carries 2", 3", and 4" thick pieces, the 3" is great! Nice and soft, and like Dragos80 said..... with foam don't even worry about that gap if it's 4" or less. You won't even know it's there..... and I'm 100% disabled from having my back shot up by a ak47!
They look very familiar, nice job, you can still swap out drawers covers to enclose the side openings, great carpeting
Looks good.
I'd recommend something towards the thinner side for the mattress. We use Thermarest self-inflating mattresses. They take up little space when deflated and rolled up, but work pretty well comfort-wise. Sometimes I'll add a thin foam camping roll-up under the Thermarest. I've got a very flaky back and this works for me, but our platform is continuous, as I have the second row seats out.
The recommendation for a thinner mattress is partly because of the height of your platform. Ultimately, this depends on your height (I'm over 6'), so if you;re shorter, you will not find this as much an issue. My deck height for the sleeper/drawer we have is right around 10" so we don't have as much storage underneath, but more room on top to move around.
I do the same as dragos80 , blocks under the 2nd row seats to level them out. Last year we just used a futon mattress. It not very packable but super comfy. Just got an exped megamat duo 10. 3" thick also super comfortable and much more compact.
I used my mattress together with my son (11 yo, but about 5' tall).
I'd take comfort over anything else.
When deflated it packs up in a rather compact size. I'll take pictures if desired.
One can do without the manual air pump I got and simply use an air compressor (which every hopefully carries off road). I really don't mind using that manual air pump. I did not want to depend on the one operated by batteries, which is even more compact in size. I got plenty of room inside the truck to carry everything I need.
Oh, I almost forgot. I chose that specific height for my "bed" due to the truck being at it's widest point right there. Just wanted to maximize the comfort level for two people. I am 6'1" and had 0 problems sleeping inside in those conditions, well... except for my son who kept on rolling over to my side and even getting on my pillow. :mad:
