Drawbacks to using Stainless fasteners?
Fort Langley, BC
Hi all - In order to replace my O2 sensors today, I needed to remove my PS slider which are held on with large Ubolts around the frame rails. I had one frozen/rusted nut that I just couldn't get off so I had to cut the Ubolt off.
So while looking online for a replacement Ubolt, I found Stainless hardware for not that much more (shipping is really the main cost). I'm thinking that the Stainless would be easier to get off next time, true?
Any drawbacks to using Stainless except for the cost?
They're generally not as strong, for one thing.
-Spike
if you use SS, apply some anti seize before tightening, SS can sometimes tear up the threads when/if you have to remove.
I've also heard what Spike said - that stainless strength doesn't match graded steels. However, it may be just fine for what you are looking for. I'd email the fastener source and tell them what grade the U bolts are on your sliders and ask their opinion. Also, a help might be to use non stainless U bolts at the correct strength grade but put copper based anti-sieze paste on them. I use the stuff all over fasteners on my truck whenever I assemble.
DougM
WB - I hate mimes, clowns and humans dressed as animals. Your avatar scares me and makes me grab for my belt holster and think about doing bad things to that avatar.....
DougM
Er, the avatar that is...
DougM
While there are applications which I would consider using stainless hardware for, slider mounting bolts wouldn't be one of them. They are substantially weaker than grade 5 which is probably what the existing u-bolts are. If you're that worried about it, use LocTite on the nuts and then give the remaining threads a little coat of grease or anti seize. Luckily, rust and corrosion aren't a big problem here.
Fixed it...
DougM
There's no grade 8 SS bolts? :confused:
Prolly a good decision , with the carbon steel and anti sleeze
There are some grades of corrosion resesistant hardware that would be strong enough , but you wouldnt want to pay for them:eek::eek:
17-4 PH is a good example of a reasonably priced strong, stainless steel.
ken
I say this depends on your application. Are you going to unbolt it every year or more? Are you in a high-salt environment? This isn't a critical application like a trailer hitch or lug nut, stainless would be acceptable if your rig sees a lot of salt. Stainless (304) is only slightly less strong than medium carbon steel, and corrosion can weaken carbon steel quickly. If it's a U-bolt, there's a good chance you can go bigger or double-up. U-bolts are cheap enough and usually easy to cut loose, chances are you'll want to put on new ones if it's many years between unbolting and replacing.
I've tried anti-seize under many vehicles for many years, and it never seems to prevent rust. I don't think that's what it's designed for. I've had better luck with high-temp moly grease in things like brake calipers than high-temp anti-seize. What is anti-seize, is it just grease with extra zinc or copper in it?
I have had consistently excellent results using thread locker under my vehicles, it fills and seals the threads with a plastic-like material. Medium strength would work well here, and it comes in liquid, gel, and my favorite, stick. I also like low-strength for just sealing threads to keep out corrosion. Still waiting for that to come out in a stick. Since you're likely not able to torque these things to spec, anti-seize would give some peace of mind that things won't easily come loose.
