Down but not Out!!!
Hernando, Ms
So I have been fighting an uphill battle on my first cruiser. I being a mechanic for nearly 14 years now have never seen such fight b/w man and vehicle. It seems every time i fix something on my fj80 something else breaks. I got the 91 with a very bad case of rust on the suspension and anything that could catch a northern snow/salt bath. So i order all the suspension pieces and bars from a fellow mudder. Then the radiator fins started crumbling so I got a new radiator & replaced all the hoses on the engine. Only to find the alternator wasn't charging. Replaced that and got new belts. Installing new belts found p/s pump leak replaced that. SO finally drove it for a week fell in love. Bought some oem rims and 315 tires. Driving down the road yesterday thinking everything is awesome I love this cruiser. Only to have blown a transfer case and or transmission. I am currently not getting any gears including park. And to add insult upon injury found my rear heater lines leaking in two spots. SO I feeling down and out almost wrote her off but after sleeping on it decided the hell with being a quitter. I am open to taking suggestions on places to buy a awesome transmission and transfer case. Any links would help my epic battle progress. Thanks for being there fellow mudders.
Tucker
Being a 91 you should have a cdl button, engage it and see if you now have rear drive only. If so ( my bet is on this) as prevoisly mentioned you have at least one front hub flange striped out. This is an extreamly common problem with these trucks. Mine for example were getting sloppy by the time I hit 90,000 km. Hopfuly this is the case, As it sounds like you are e dedicated enthousiest as most of us here are.
And remember, you now own a world renouned legend! it's just suffering from some neglect from the prevous owner.
Transfer is in High tried the cdl button and the low range nothing and nothing. I will get it up on my lift monday hopefully. Yes, the derelict of the previous owner and my kicking him in the nuts should I see him again is the stuff dreams are made of. Of course I knew this vehicle would pose problems from the initial look over upon buying. I love a good challenge though.
I looked at marlin crawler they look to have some good stuff. Anyone use anyone else aftermarket wise.
FWIW, the transfer cases on these vehicles seldom fail even in cases of severe neglect. You get no drive in high range or low range and no parking pawl.
Any sounds from downunder? Either the transfer is in neutral (check the linkage) or the CDL actuator is not working when you shift into low range. That leaves you with an open center diff and if one of the front drive flanges was stripped, you'd get nothing.
When shifting from drive back into Park it sounds like a slight grinding noise. When the incident happened on the road there was like 3 - 4 seconds grinding then nothing just the engine revving. Is the transfer case shifter linkage adjustable?
The linkage is not adjustable that I remember, but it is all held in place with a cotter pin and some small bits. Worth a look anyhow.
I would pop the grease caps off the front drive plates while the vehicle has all 4 on the ground. Put her in drive with the handbrake set and look for the rotating shaft.
That's a 5 minute check that will tell us much. No lift required.
A 30 second version would be to set the handbrake, put her in drive and look for a rotating driveshaft.
Tucker,
Details here. When you put the truck in low range does the center lock light come on? Does it come on in high range when you engage the center diff lock switch? Is the tranny full? Is the transfer case full? Did you do the drive plate check mentioned by John Held?
I'm betting you've got a yawner of a tiny little problem that's already been identified.
DougM
The t-case linkage is adjustable, but the adjustments are on top of the t-case.
I'm not sure how to access it, even with my 1" body lift it doesn't seem like I can get to it...
DougM
Trans is full, and transfer is full. Cdl light is lit upon pushing and when pulled down into low range going to perform the the drive plate check and make sure the linkage is cool in a few hours.
