Doubling An Orion
SO.WEST,COLORADO
Has anyone doubled an orion yet. Would it use the same parts as if you were to double stock t/cases. I have an orion, but went wheeling with some buddies and both had doublers, and that stupid low comes in handy at times. I have an x-tra case and was thinking maybe........ Any input.... POSER ?
What doubler are you considering?
74fj40 said:
idk what doubling means. and idk what dual transfercases are. i know that the name is pretty self explanitory, but how does the whole setup work?
generally doubling means adding a second gear reduction box between the transmission ant transfer case, so you end up with an additional shifter. Then you have the option of a 2 to 1 low range gear, or a 4 to 1 low range gear, or both in low range and they multiply giving an 8 to 1 low range gear. this all depends on the gearing in the transfercase and the additional gear box.
The second gear box can come in many forms. One popular option is to use the front 1/2 of a toyota mini truck transfercase. They are gear driven and strong for their size and weight. In addition they are cheap and there are lots of them. you take the components from the stock transfercase and remove the back portion of it, then bolt adapters onto both ends to it bolts up to the back of the transmission and the front of the transfercase. As you can immagine it will extend the length of the drive train. There are a number of other options to use for the extra gear box from a couple different manufacturers. The np203 can be split in a similar way to the toyota mini case and is commonly used for gm drivetrains.
I hope this explains it.
As for the orion, I would just go with a low gear set in a toy box and into a stock split case. You could probably sell your orion for the cost of a toybox and the low gears and use that with your extra transfer case or find a split case. Might end up being cheaper in the long run, becasue you will probably have to use either a toybox a rockbox anyway. Plus you would have an easier time finding parts if any of it broke, but since you have the orion already you would just need a standard geared toybox.
Don't know if you have considered it, but a sm465 swap might give you all the crawl you need and still keep a longer rear shaft.
Just some options to think about.
nuclearlemon said:
why? they're stupid low as it is...:confused:
Well i'm still running 4-11s w/35s cause i like the gearing for on road. Ran some trails in Farmington,NM. And lower gearing would have been handy in some of the pucker factor spots that you would'nt want to bump up. Just thinkin' out loud.
zornff said:
Well i'm still running 4-11s w/35s cause i like the gearing for on road....
What transmission? H42 with original 2F?
4.11s w/35s is a good highway rpm tamer.
I've got an Orion with an H42 and 5.29s in one of my rigs. I'll probably double it up before next season (gonna run it the way it is this summer). I'll use either an toybox approach with the stock 2.28 gearing or an NP203 with the 2:1. Probably keeping the H42. I've got the parts for either approach.
I'm not really looking for the stupid low. The Orion is low enough for 99% of what I do with it. But to regain a normal low range. I've already realized that I don't like the gap between high and low range.
In answer to your question, whatever doubler will work with a stock case should work just as well with the Orion. There's no differences that will affect this.
Mark...
H42 & 2F.
An orion w/5.29's would be plenty low w/35's, but like you say, normal 2 low would be nice to have. With 33's my gearing was a little better/lower, but now its a little taller than i want. I don't know if there is ever a perfect set up, i guess i should shut up and run it, or re-gear and rev the heck out of it on road.:o
I put a 2.28 Toybox in front of an Orion last year....when used with the SM465 and 5.29's in the diff, this thing is 313.59:1 low-low...
Is it slow? Yes.
Is it fun? Yes.
I ran a 420 with 4:11's and a 2.3 stock Land Cruiser case for a long time...all the way to 38" tires...yes on the street too....
Moab and Farmington NM were done with 33's and 35's...back in '95 and '96.
Bang for the buck? 420/465 swap to a stock case....can crawl all day long with that....
Since installing the 4.3:1 Atlas behind the 420 in the Red truck, there have been few instances that I have not had the wheel speed for some things that I was doing....but you learn how to adapt....or you spend more money!! :)
Good luck!
-Steve
SWEEEET, Thanks for the input . Decisions $, Decisions.......
Since you still have the 2F along with 4.11s, the easiest way would be to install an H41 with 4.93 first gear. Bolts right up for an ~80 to 1 final crawl ratio in first gear 4-Lo. With the H42's 3.54 first gear, final crawl is 58 to 1. But H41s are expensive and uncommon.
SM465 would be lower (~103:1). SM420 even lower (~115:1). But both require adapters and may involve front driveshaft clearance issues (minor). SM465 is usually cheap to source, though (~$100). Treeroot has placed an excellent tech article on the tech links page covering SM465 install:
http://www.root45.com/SM465Orion/
All these options retain the 4.11 R&P for decent highway rpms with tall tires.
Keep in mind the driveshaft cost too in this venture. That is what drove me to the H41 route. The combo is plenty slow for most wheeling and high enough for on road usage. Just my 2 Cents.
