Double shift indication - shifting into D engages L instead = FIXED!
I'm posting this because I did a lot of searching recently, a LOT, and found no definitive answer to the problem, but did find several others who had the same issue. So hopefully in the future others will find this post in a search and get right to fixing their rig.
My tranny was shifting into low instead of drive, and both indicator lights would light up at the same time - D and L. At first it came and went, even for months at a time, but then the problem became steady and the truck was un-driveable except for in either L or 2. Not exactly highway speeds.
The problem was, as some here had guessed, the Park Neutral Safety Switch! Not the connector but the unit itself.
I saw threads where the P/N switch caused a no start situation, and where members had the same problem as me, but never both together. So here it is!
The problem
imageuploadedbyih8mud-forum1421228521-646250-jpg.1017196
The solution
My "D" doesn't light up. Problem solved. :)
JCruse, thanks for the follow up! So, what did you do? Replace it or fix it somehow? Reason I ask is my wife's Acura TSX was bitching about a gear selector switch (error code). I pulled it apart, cleaned it, greased it with silicone grease and reassembled. Problem gone, saved 80 bucks.
Yeah I didn't feel like dealing with it right now and it's been going on so long I just said fxxx it and brought it to the shop. Had him do my full brake job too. I got a very good deal on the labor because he owed me, so...
I have to be very picky about what work I do. It sucks having blown discs and crushed vertebrae in the lower spine. :meh:
By posting this I wanted the next guy who searches about having their tranny shifting into whatever it feels like to find an answer quicker than I did.
JCruse, I just wanted to say thanks for the information on this thread. I had the same symptoms as you described and upon my initial search on Mud, I didn't think I was going to find any answers. After much digging, I came across this one and bamm! Swapped the NSS and all is well again. Thank You!
