I just recently installed a double din, replacing the stock unit in my 1995 80 series. Bought a Clarion double din with Ipod connection (from the rear of the unit). Fit perfect. It was very tight behing the new unit. You must be creative in storing the cables etc. I sourced the unit from Crutchfield, included was the required wiring kit. Very simple install with the wiring kit. If you have a manual antenna, DO NOT CONNECT THE WIRE FOR A POWERED ANTENNA. If you do, you will run the risk of overheating the new unit. Spend time with making the wiring connection from the new unit to the wiring kit.
Removing the front dash took longer than the install. In some cases you will have to disconnect the stock amp (which is located behind the glove box). i did not. The new wiring kit bypassed the stock amp. Four screws held in the orginal unit. You will use the orginal mounting hardware with the new unit.
If you search the forum, you will find great info for installing a double din unit.
By the way, no cutting is required of the dash face plate.
