Door weatherstripping and seals ---- Any good source?
Arizona
I'm planning to replace all the weatherstrips in my 4 doors on my '96 80. Does anyone know a (1) a guide to how many pieces there are, exactly, and (2) a source for quality weatherstripping? Any info would be much appreciated.
I bought is from the dealer. Each door has a single outer seal that wraps all the way around
All 5 still available from Toyota.
Partsouq.com
Enter your VIN and all part numbers are available to you. You can order directly from them or shop around.
That's the long piece that goes around the door and sets against the frame to (basically) keep wind out, yes?
Yup, super easy to install as well. The seal is wedged into the door at the top and then there are clips are around the side and bottom.
Partsouq.com
Yes, that worked well with the VIN. But it looks like they only ship from UAE. Do you know if there is a from-the-US shipping option?
I order $$$ from Partsouq every month nothing to worry about order them up.
Use the part numbers you got from Partsouq and shop around. Ourisman Toyota in VA is my alternate source, but they tend to be more expensive than Partsouq on most parts.
FWIW, I've ordered boatloads of stuff from Partsouq. They ship quickly.
This is very helpful information. I really appreciate it.
You mentioned 5 parts (per door). I count 4. What am I missing?
1. Inner window door weather strip
2. Outer window door weather strip
3. Weather strip glass run (sets in the door, for the top, left & right of window
4. Weather strip door (sets in the frame, seals the door when shut, on all 4 sides of the door.
What part am I missing?
That’s right should be 4 per door.
He may be referring to the rear door?
The rear door has trim that wraps the entire opening with edge trimmer and then is a second piece below the hatch.
When I replaced the weather stripping on my truck I did the 4 doors and the hatch.
I being trying to order the weatherstrip 62312-60010-03 but everywhere show discontinue can someone share their part number please ?
That's door opening trim in grey. The part number is correct if that's what you're referring to.
I believe the grey and oak have been discontinued for quite some time now. You might have some luck looking in the classifieds section.
