Door Stop Limiter Bracket options??
sleepycruiser
I will get by….I will survive
Asheville, North Carolina
On my ‘64 both doors are missing the brackets that limit the door from opening and breaking the side mirror….ugh. They both pulled off at some point I suppose.
SOR has them and I would order them, but shipping is $50…when it should be about $6…throw them in a bag and send them. I’ve heard they have high shipping, but that is wild.
Any other options for someone that is not technical with welding, etc?
I stole the attached pic from another thread. ;-)
It would not be hard to bend one up. This one was poorly repaired sometime in the past. I was able to remove it, repair the metal under it then tack it back on.
My tabs on the door were cut off so i did a quick and dirty fix by drilling a small hole where the tabs were on the door and attaching a small section of black 1" tubular webbing with a sheet metal screw and ran the other end thru the body hole with a knot. still works after 16 years.
:beer:
ty
